Datasheet BM90 (Microchip) - 7
Manufacturer | Microchip |
Description | Bluetooth 3.0 Multi-Speaker Stereo Audio Module |
Pages / Page | 31 / 7 — BM90 Module. 3.0 PIN DESCRIPTION. TABLE 3-1: BM90 PIN DESCRIPTION. Pin. … |
File Format / Size | PDF / 1.7 Mb |
BM90 Module. 3.0 PIN DESCRIPTION. TABLE 3-1: BM90 PIN DESCRIPTION. Pin. Pin No. Name. Description. Type
BM90 Module 3.0 PIN DESCRIPTION TABLE 3-1: BM90 PIN DESCRIPTION Pin Pin No. Name Description Type
IO, default pull-high input 1 I/O P3_5 Phone button Embedded ROM/External Flash enable 2 I EAN H: Embedded; L: External Flash IO, default pull-high input 3 P P3_0 Low: N_SPK Role Master/Slave IO, default pull-high input 4 I/O P2_0 System Configuration, H: Application L: Baseband(IBDK Mode) IO, default pull-high input . 5 I/O P0_0 Audio amplifier enable IO, default pull-high input 6 I/O P0_4 NFC R-channel analog headphone output, for cap-less and single-ended 7 AO SPKR application both Headphone common mode output/sense input. Cap-less application 8 AO AOHPM only. L-channel analog headphone output, for cap-less and single-ended 9 AO SPKL application both Positive power supply/reference voltage for CODEC. 10 AP VDDA Reserve for external cap to fine tune audio frequency response. Do not add external power to this pin. 11 AI MIC1_P Mic 1 mono differential analog positive input 12 AI MIC1_N Mic 1 mono differential analog negative input 13 AP MIC_BIAS Microphone biasing voltage page 7 Document Outline Bluetooth® 3.0 Multi-Speaker Stereo Audio Module Features Description Applications Table of Contents 1.0 DEVICE OVERVIEW FIGURE 1-1: APPLICATION BLOCK DIAGRAM Audio Interface FIGURE 1-2: Analog audio interface block diagram FIGURE 1-3: Twin Speaker Link block diagram 2.0 Key Features Table 3.0 PIN DESCRIPTION TABLE 3-1: BM90 PIN DESCRIPTION 4.0 SPECIFICATIONS 4.1 SPECIFICATIONS Table 4-1: Absolute Maximum Specifications Table 4-2: Recommended operating condition Table 4-3: Battery Charger Table 4-4: LED driver Table 4-5: Digital IO Table 4-6: Audio codec Digital to Analogue Converter Table 4-7: Audio codec Analogue to Digital Converter Table 4-8: Transmitter section for BDR Table 4-9: Transmitter section for EDR Table 4-10: Receiver section for BDR Table 4-11: Receiver section for EDR 4.2 PRINTED ANTENNA PERFORMANCE Table 4-12: Antenna Parameters FIGURE 4-1: Antenna 3D radiation pattern @2441 MHz 4.3 BQTF INFORMATION FIGURE 4-2: BQTF Information 4.4 CURRENT CONSUMPTION Table 4-13: Single Mode current consumption Table 4-14: Twin Mode: Master current consumption Table 4-15: Twin Mode: Slave current consumption 5.0 APPLICATIONS 5.1 EXTERNAL CONFIGURATION FIGURE 5-1: External Configuration Header Connections TABLE 5-1: SYSTEM CONFIGURATION SETTINGS 5.2 LED DRIVER 5.3 FUNCTION OF PIN TABLE 5-2: IOs for Buttons TABLE 5-3: IOs for added functions 5.4 Adaptive Frequency Hopping (AFH) 5.5 MULTI-SPEAKER 5.5.1 TWIN SPEAKER LINK TECHNOLOGY INTRODUCTION 5.5.1.1 TWIN SPEAKER LINK Figure 5-2 A2DP Twin Speaker Link Diagram 5.6 Mounting Details 5.7 Module Dimension FIGURE 5-3: BM90 module FIGURE 5-4: Outline Dimension FIGURE 5-5: Module Foot print 5.8 Main Board Antenna Area Layout Guide FIGURE 5-6: Mother Board Antenna Area Layout Guide 5.9 RFLOW PROFILE 5.9.1Soldering Recommendations FIGURE 5-7: Reflow profile 6.0 REFERENCE CIRCUIT FIGURE 6-1: BM90 reference circuit 7.0 PACKING INFORMATION 7.1 QR code label information 7.2 Storage standard 7.3 Ordering Information 7.4 Tray Dimensions 7.5 Packing Method
