User Guide RN24, RN25, RN41, RN42, RN41XV, RN42XV, RN220XP, RN240, RN270, RN274 (Microchip) - 8
ManufacturerMicrochip
DescriptionRN-BT-DATA-UG Bluetooth Data Module Command Reference & Advanced Information
Pages / Page83 / 8 — RN-BT-DATA-UG. ---. Note:. 1.3.3. Enter Command Mode. TABLE 1-1:. SERIAL …
RN-BT-DATA-UG. ---. Note:. 1.3.3. Enter Command Mode. TABLE 1-1:. SERIAL PORT SETTINGS. Setting. Value
RN-BT-DATA-UG --- Note: 1.3.3 Enter Command Mode TABLE 1-1: SERIAL PORT SETTINGS Setting Value
link to page 8 link to page 9 link to page 44 link to page 44 link to page 26
RN-BT-DATA-UG
When you are finished configuring, reset the module or send the
command, which causes the module to exit configuration mode and allows data to pass normally.
Note:
Configuration mode (local or remote) is NEVER enabled when the module is in auto-mode and is connected over Bluetooth.
To enter command mode, launch a terminal emulator and specify the module’s default settings. Table 1-1 shows the serial port settings.
Port COM port to which you attached the module Baud rate 115200 Data rate 8 bits Patiry None Stop bits 1 Flow control None Type $$$ into the terminal emulator to enter command mode. The module returns the string CMD, which indicates that your connection and terminal settings are correct. While in command mode, the module accepts ASCII bytes as com- mands. When you enter a valid command, the module returns AOK. It returns ERR for an invalid command and ? for unrecognized commands. Type h <cr> to see a list of com- mands. A quick check to confirm that you are in command mode is to type the X <cr> command after entering command mode. This command shows the a summary of the module’s current settings, such as the Bluetooth name, device class, and serial port settings. See Figure 1-2. To return to data mode, type --- <cr> or reset the module and re-connect.
Note:
The module supports a fast data mode. In this mode, the module does not go into command mode even if it receives $$$. If you do not enter command mode within the configuration window (60 seconds), the module enters fast data mode. See “ST,<value>” on page 26 and “Configuration Timer Set- tings” on page 44 for more information on setting the configuration window. www.rovingnetworks.com Version 1.0r 3/26/13 page 8 Advanced Information Document Outline Chapter 1. Introduction 1.1 Overview 1.2 Evaluation Boards & Reference Designs 1.3 Command Mode vs. Data Mode Figure 1-1: Data & Command Modes 1.3.1 Configuring the Module over the UART Port 1.3.2 Remote Configuration Using Bluetooth 1.3.3 Enter Command Mode Table 1-1: Serial Port Settings Figure 1-2: View Current Settings 1.4 Operating Modes 1.5 Using Dipswitches & GPIO Pins for Configuration Table 1-2: Dipswitch & GPIO Settings Table 1-3: GPIO Assignments 1.6 Making a Bluetooth Connection 1.6.1 Discovery Figure 1-3: Discover the Bluetooth Module 1.6.2 Pairing Figure 1-4: Pair with the Bluetooth Module Figure 1-5: Bluetooth COM Port Settings 1.6.2.1 Pairing with a Computer or Smart Phone 1.6.3 Connecting Figure 1-6: PC’s Bluetooth Radio MAC Address Figure 1-7: Terminals A & B 1.6.4 Security Modes Chapter 2. Command Reference 2.1 Command Syntax Table 2-1: Command Types 2.2 SET Commands 2.2.1 S7,<flag> Table 2-2: 7-Bit Data Mode Values 2.2.2 SA,<value> Table 2-3: Set Authentication Values 2.2.3 SB,<value> Table 2-4: Set Break Values 2.2.4 SC,<value> 2.2.5 SD,<value> 2.2.6 SE,<value> 2.2.6.1 Firmware version 5.40 & Higher 2.2.6.2 Firmware Prior to Version 5.40 Table 2-5: Set Encryption Enable 2.2.7 SF,1 2.2.8 SH,<value> Table 2-6: HID Flag Register Bits 2.2.9 SI,<hex value> 2.2.10 SJ,<hex value> 2.2.11 SL,<char> Table 2-7: UART Parity Values 2.2.12 SM,<value> Table 2-8: Mode Values 2.2.13 SN,<string> 2.2.14 SO,<string> 2.2.15 SP,<string> 2.2.16 SQ,<mask> Table 2-9: Special Configuration Settings Values 2.2.17 SR,<hex value> 2.2.18 SS,<string> 2.2.19 ST,<value> Table 2-10: Configuraion Timer Settings 2.2.20 SU,<value> 2.2.21 SW,<value> 2.2.22 SX,<flag> Table 2-11: Bonding Values 2.2.23 SY,<hex value> Table 2-12: Power Settings (August 2012 and Later) Table 2-13: Power table (before August 2012) 2.2.24 SZ,<value> 2.2.25 S~,<value> Table 2-14: Profile Values 2.2.26 S-,<string> 2.2.27 S?,<flag> Table 2-15: Role Switch Values 2.2.28 S$,<char> 2.2.29 S|,<value> 2.3 GET Commands 2.3.1 D 2.3.2 E 2.3.3 GB 2.3.4 GF 2.3.5 GK 2.3.6 GR 2.3.7 G& 2.3.8 G<char> 2.4 Change & Action Commands 2.4.1 $$$ 2.4.2 --- 2.4.3 + 2.4.4 & 2.4.5 C 2.4.6 C,<address> 2.4.7 CF,<address> 2.4.8 CFI 2.4.9 CFR 2.4.10 CT,<address>,<value> 2.4.11 F,1 2.4.12 H 2.4.13 I,<value 1>,<value 2> 2.4.14 IN<value 1>,< value 2> 2.4.15 IQ 2.4.16 IS<value> 2.4.17 IR<value> 2.4.18 J 2.4.19 K, 2.4.20 L 2.4.21 M 2.4.22 O 2.4.23 P,<char> 2.4.24 Q 2.4.25 R,1 2.4.26 T,<flag> Table 2-16: T Command Values 2.4.27 U,<value 1>,<value 2> 2.4.28 V 2.4.29 W 2.4.30 Z 2.5 GPIO Commands 2.5.1 S@,<hex value> 2.5.2 S&,<hex value> 2.5.3 S%,<hex value> 2.5.4 S^,<hex value> 2.5.5 S*,<hex value> 2.5.6 Controlling the GPIO Pins 2.5.7 Setting GPIO Pin Power-Up Values 2.5.8 Setting GPIO8, GPIO9, GPIO10 & GPIO11 Chapter 3. Advanced Topics 3.1 Power Management Table 3-1: Power Management Methods 3.1.1 Optimizing Inquiry (Discovery) & Page (Connection) Windows 3.1.2 Sniff Mode 3.1.3 Enabling Deep Sleep 3.1.4 Disabling Output Drivers 3.1.5 Lowering Transmit Power Table 3-2: Power Settings 3.2 Configuration Timer Settings Table 3-3: Configuration Timer Settings 3.3 Interfacing to a Microprocessor 3.3.0.1 How do I know the module is ready for command mode? 3.3.0.2 Which hard signals should I connect? 3.4 HCI Mode 3.4.1 HCI over UART 3.4.2 HCI over USB 3.5 Profile Settings & Features Table 3-4: Profile Change Values 3.6 Using GPIO Pins as Modem Control Signals 3.7 Design Concerns 3.7.1 Hardware Signals 3.7.1.1 Reset Circuit 3.7.1.2 Factory Reset GPIO4 3.7.1.3 Connection Status Table 3-5: GPIO5 Status Table 3-6: GPIO2 Status 3.7.1.4 Using the SPI Bus for Flash Upgrades 3.7.1.5 Hardware Connections & Power 3.7.2 LED Status Table 3-7: Green LED Status 3.7.3 Optimizing for Latency or Throughput 3.7.4 Limitations of 7-Bit Data Mode 3.7.5 Common Issues 3.7.5.1 My Bluetooth client can see the FireFly module and its serial service, but I can’t connect 3.7.5.2 How do I change the client’s COM port? 3.7.5.3 How do I connect to more than one FireFly module from the same client at the same time? 3.7.6 Discovery & Connection Example Sequence 3.7.7 Auto-Pairing/Auto-Connection Table 3-8: GPIO Pin/Dipswitch Settings for Auto-Pairing/Connection 3.8 Serial Adapter Configuration Figure 3-1: DB9 Connector Pins Table 3-9: DB9 Connector Pin-Out 3.9 Null Modem & Flow Control Jumpers Figure 3-2: RN422, RN240, RN270 & RN274 Jumpers Figure 3-3: RN220XP Jumpers 3.10 Dipswitch Settings Figure 3-4: DipSwitches Table 3-10: Switch Functions Chapter 4. Applications 4.1 Instant Cable Replacement 4.1.1 Hardware Pairing Using Dipswitches Figure 4-1: Cable Replacement DipSwitch Settings for Pairing Figure 4-2: Setting DipSwitch 2 for Deployment 4.1.2 Software Pairing Using Commands Chapter 5. HID Profile 5.1 Overview Figure 5-1: Typical HID Environments 5.2 HID Firmware Overview 5.2.1 Operational Modes 5.2.2 Profile Configuration 5.2.3 Device Discovery & Pairing 5.2.4 HID Flag Register Table 5-1: HID Flag Register Bits 5.2.4.1 Bit 9 5.2.4.2 Bit 8 5.2.4.3 Bits 7-4 5.2.4.4 Bit 3 5.2.4.5 Bits 2-0 5.3 HID Reports Table 5-2: Data Interpretation 5.3.1 Translation Mode 5.3.2 Keyboard Shorthand Mode 5.3.3 Raw Report Mode 5.3.4 Special Reports & Modes 5.3.4.1 Output Reports Table 5-3: Status Byte Definitions 5.3.4.2 Apple Virtual Keyboard 5.3.4.3 Key Map Register 5.3.4.4 Disconnect Key 5.3.4.5 Consumer Report Table 5-4: Data Byte Format 5.3.4.6 Scan Code Tables: UART (ASCII) to HID Report Table 5-5: UART-to-HID Scan Code Table 5-6: ASCII to HID Report (to Host) Scan Codes 5.4 HID References Appendix A. Factory Defaults Table A-1: Factory Default Settings Appendix B. Command Quick Reference Guide Table B-1: Set Commands Table B-2: Get (Display) Commands Table B-3: Action Commands (Part 1 of 2) Table B-4: GPIO Commands Appendix C. Firmware Revision History C.1 Version 6.15 (3/26/2013) C.2 Version 6.12 (Limited Release) C.3 Version 6.11 C.4 Version 6.10 C.4.1 HID Firmware Known Issues C.5 Version 4.77 (8/10/2009) C.6 Version 4.74 (3/7/2009) Appendix D. Document Information Conventions Used in this Guide Recommended Reading Document Revision History
