Datasheet RN41XV, RN42XV (Microchip)
ManufacturerMicrochip
DescriptionBluetooth Module
Pages / Page10 / 1 — RN4142XV-DS. RN41XV & RN42XV Bluetooth Module. Features:. 1.0. …
File Format / SizePDF / 335 Kb
RN4142XV-DS. RN41XV & RN42XV Bluetooth Module. Features:. 1.0. DESCRIPTION. Applications:
Datasheet RN41XV, RN42XV Microchip
RN4142XV-DS RN41XV & RN42XV Bluetooth Module Features:
• Fully qualified Bluetooth® version 2.1 Class 1 (RN41XV) and Class 2 (RN42XV) data module, supports version 2.1 + Enhanced Data Rate (EDR) • Backwards-compatible with Bluetooth version 2.0, 1.2, and 1.1 • Pin compatible with widely used 2 x 10 2-mm socket typically used by 802.15.4 applications • RN42XV: 26 μA sleep, 3 mA connected, 30 mA transmit • RN41XV: 30 mA connected, < 10 mA sniff mode • UART data connection interface • Supports secure simple pairing (SPP) • Sustained data rates: 240 Kbps (slave), 300 Kbps
1.0 DESCRIPTION
(master) • Embedded Bluetooth stack profiles: SPP and HID The RN41XV and RN42XV are small form factor, low- profile support as well as GAP, SDP, RFCOMM, power Bluetooth radio modules offering plug-in com- and L2CAP protocols patibility for the widely used 2 x 10 (2-mm) socket typi- • Bluetooth SIG certified cally used by 802.15.4 radio modules. • Certifications: FCC, IC, CE Based on the popular 2 x 10 (2-mm) socket footprint • Environmentally friendly, RoHS compliant often found in embedded applications, the Roving Net- works’ RN41XV and RN42XV modules provide Blue-
Applications:
tooth connectivity in legacy and existing designs that may have been based upon the 802.15.4 standard. • Bluetooth replacement for 802.15.4 modules • Cable replacement The RN41XV Class 1 Bluetooth module is based on the RN41, and the RN42XV Class 2 Bluetooth module is • Barcode scanners/readers based on the RN42. These modules are simple to • Measurement and monitoring systems design in and are fully certified, making them a com- • Industrial sensors and controls plete embedded Bluetooth solution. The RN42 is func- • Medical devices tionally compatible with the RN41. • Computer accessories The Class 1 RN41 module has a range up to • Asset tracking 100 meters. The Class 2 RN42 module has a range up to 20 meters. www.rovingnetworks.com Version 1.0 12/3/12 page 1 Document Outline Features: Applications: 1.0 Description 2.0 Overview FIGURE 2-1: RN41XV & RN42XV Dimensions 3.0 Typical Application Schematic FIGURE 3-1: Application Schematic, Note 1 4.0 Design Concerns 4.1 Powering the Module 4.2 Reset Circuit 4.3 Factory Reset Using GPIO4 4.4 Connection Status 5.0 Compliance Information 6.0 Ordering Information
