Datasheet ZXTP56060FDBQ (Diodes)
ManufacturerDiodes
Description60V Dual PNP LOW VCE(sat) Transistor
Pages / Page8 / 1 — ZXTP56060FDBQ. 60V DUAL PNP LOW VCE(sat) TRANSISTOR. Description. …
File Format / SizePDF / 502 Kb
ZXTP56060FDBQ. 60V DUAL PNP LOW VCE(sat) TRANSISTOR. Description. Mechanical Data. Features. Application
Datasheet ZXTP56060FDBQ Diodes
ZXTP56060FDBQ 60V DUAL PNP LOW VCE(sat) TRANSISTOR Description Mechanical Data
This bipolar junction transistors (BJT) is designed to meet the • Case: U-DFN2020-6 (SWP) (Type A) with Sidewall Plating stringent requirements of automotive applications. • Case Material: Molded Plastic. “Green” Molding Compound. UL Flammability Rating 94V-0
Features
• Moisture Sensitivity: Level 1 per J-STD-020 • Terminals: Finish—Matte Tin, Solderable per MIL-STD-202, • BVCEO > -60V Method 208 • IC = -2A High Continuous Collector Current • Weight: 0.0065 grams (Approximate) • RCE(sat) = 250mΩ for a Low Equivalent On-Resistance • Sidewall Tin Plating for Wettable Flanks in AOI • P
Application
D Up to 2.47W for Power Demanding Applications • Low Profile 0.6mm High Package for Thin Applications • Matrix LED Lighting •
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)
• Power Management •
Halogen and Antimony Free. “Green” Device (Note 3)
The ZXTP56060FDBQ is suitable for automotive applications requiring specific change control; this part is AEC-Q101 qualified, PPAP capable, and manufactured in IATF16949 certified facilities. https://www.diodes.com/quality/product-definitions/
U-DFN2020-6 (SWP) (Type A) C1 B2 E2 6 C1 C2 1 E1 B1 C2 Bottom View Device Symbol Top View Pinout
Ordering Information
(Note 4)
Part Number Marking Reel Size (inches) Tape Width (mm) Quantity Per Reel
ZXTP56060FDBQ-7 2D9 7 8 3000 ZXTP56060FDBQ-13R 2D9 13 8 10,000 Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. For packaging details, go to our website at https://www.diodes.com/design/support/packaging/diodes-packaging/.
Marking Information
U-DFN2020-6 (SWP) (Type A) 2D9 = Product Type Marking Code Y = Year: 0~9 2D9 W = Week: A~Z: 1~26 week; a~z: 27~52 week; z represents YWX 52 and 53 week X = A~Z: Internal code ZXTP56060FDBQ 1 of 8 17 February 2020 Datasheet number: DS39605 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated Document Outline Mechanical Data Description This bipolar junction transistors (BJT) is designed to meet the stringent requirements of automotive applications. Features BVCEO > -60V Application Matrix LED Lighting Power Management Characteristic Characteristic Marking Information 2D9 YWX 2D9 = Product Type Marking Code Y = Year: 0~9 W = Week: A~Z: 1~26 week; a~z: 27~52 week; z represents 52 and 53 week X = A~Z: Internal code Package Outline Dimensions Suggested Pad Layout
