Datasheet ZXTP56020FDBQ (Diodes) - 4
Manufacturer | Diodes |
Description | 20V Dual PNP LOW VCE(sat) Transistor |
Pages / Page | 7 / 4 — ZXTP56020FDBQ. Electrical Characteristics – Q1 & Q2. Characteristic. … |
File Format / Size | PDF / 412 Kb |
ZXTP56020FDBQ. Electrical Characteristics – Q1 & Q2. Characteristic. Symbol. Min. Typ. Max. Unit. Test Conditions. www.diodes.com
ZXTP56020FDBQ Electrical Characteristics – Q1 & Q2
(@TA = +25°C, unless otherwise specified.)
Characteristic Symbol Min Typ Max Unit Test Conditions
Collector-Base Breakdown Voltage BVCBO -20 V IC = -100µA Collector-Emitter Breakdown Voltage (Note 12) BVCEO -20 V IC = -10mA Emitter-Base Breakdown Voltage BVEBO -7 V IE = -100µA Collector-Base Cutoff Current -100 nA VCB = -16V, IE = 0 I CBO -50 µA VCB = -16V, IE = 0, TA = +150°C Emitter-Base Cutoff Current IEBO -100 nA VEB = -5.6V, IC = 0 250 VCE = -2V, IC = -100mA 210 VCE = -2V, IC = -500mA DC Current Gain (Note 12) h 170 FE VCE = -2V, IC = -700mA 160 VCE = -2V, IC = -1A 100 VCE = -2V, IC = -2A -110 IC = -500mA, IB = -50mA -220 IC = -1A, IB = -50mA Collector-Emitter Saturation Voltage (Note 12) VCE(SAT) mV -200 IC = -0.7A, IB = -7mA -390 IC = -2A, IB = -200mA Equivalent On-Resistance (Note 12) RCE(SAT) 220 mΩ IE = -1A, IB = -50mA -1 IC = -0.5A, IB = -50mA Base-Emitter Saturation Voltage (Note 12) VBE(SAT) -1.1 V IC = -1A, IB = -50mA -1.25 IC = -2A, IB = -200mA Base-Emitter Turn-on Voltage (Note 12) VBE(ON) -0.9 V VCE = -2V, IC = -0.5A Turn-On Time tON 60 ns IC = -1A, IB1 = -IB2 = 50mA; Delay Time tD 10 ns TA = +25°C Rise Time tR 50 ns Note: 12. Measured under pulsed conditions. Pulse width 300µs. Duty cycle 2%. ZXTP56020FDBQ 4 of 7 April 2017 Datasheet number: DS38567 Rev.1 - 2
www.diodes.com
© Diodes Incorporated
