Datasheet DW01A (Fortune Semiconductor) - 6
ManufacturerFortune Semiconductor
DescriptionOne Cell Lithium-ion/Polymer Battery Protection IC
Pages / Page14 / 6 — DW01A 9. Absolute Maximum Ratings (GND=0V, Ta=25°C unless otherwise …
File Format / SizePDF / 644 Kb
DW01A 9. Absolute Maximum Ratings (GND=0V, Ta=25°C unless otherwise specified)
DW01A 9 Absolute Maximum Ratings (GND=0V, Ta=25°C unless otherwise specified)
Symbol Rating Unit Input voltage between VCC and GND * VCC GND-0.3 to GND+10 V OC output pin voltage VOC VCC -24 to VCC +0.3 V OD output pin voltage VOD GND-0.3 to VCC +0.3 V FO
Fo P R
r R ro TU
ef pe NE
er rti
en es
ce
O
nl
y Item CS input pin voltage VCS VCC -24 to VCC +0.3 V Operating Temperature Range TOP -40 to +85 °C Storage Temperature Range TST -40 to +125 °C Note: DW01A contains a circuit that will protect it from static discharge; but please take special care that no
excessive static electricity or voltage which exceeds the limit of the protection circuit will be applied to it. Rev. 1.1 6/14
