Datasheet FP6277 (Feeling Technology) - 8
ManufacturerFeeling Technology
Description500kHz 7A High Efficiency Synchronous PWM Boost Converter
Pages / Page12 / 8 — FP6277. Function Description. Operation
File Format / SizePDF / 616 Kb
FP6277 Function Description Operation
FP6277
Operation
The FP6277 is a current mode synchronous boost converter. The constant switching frequency is
500 kHz and operates with pulse width modulation (PWM). Build-in 30mΩ high side switch and 30mΩ
low side switch provides a high efficient conversion. Soft Start Function
Soft start circuitry is integrated into FP6277 to avoid inrush current during power on. After the IC
is enabled, the output of error amplifier is clamped by the internal soft-start function, which causes
PWM pulse width increasing slowly and thus reducing input surge current. Current Limit Program
A resistor between OC and GND pin programs peak switch current. The resistor value should be
between 26.5k and 300k. The current limit can be set from 7A to 0.8A. The OC pin can’t float must
connect a resistor to ground. Keep traces at this pin as short as possible. Do not put capacitance at this
pin. Set the over current trip point according to the following equation: IOCP  180000
 0.2
R3 Over Temperature Protection (OTP)
FP6277 will turn off the power MOSFET automatically when the internal junction temperature is
higher than 150°C. The power MOSFET wake up when the junction temperature drops 30 °C under the
OTP threshold temperature. This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice.
No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Website: http://www.feeling-tech.com.tw Rev. 0.65 8/12
