Datasheet ADCMP391, ADCMP392, ADCMP393 (Analog Devices) - 4
DescriptionDual Comparator with Known Power-Up State
Pages / Page17 / 4 — ADCMP391/ADCMP392/ADCMP393. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. …
RevisionD
File Format / SizePDF / 377 Kb
ADCMP391/ADCMP392/ADCMP393. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL RESISTANCE. Parameter. Rating
ADCMP391/ADCMP392/ADCMP393 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 THERMAL RESISTANCE Parameter Rating
ADCMP391/ADCMP392/ADCMP393 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL RESISTANCE Parameter Rating Table 3. Thermal Resistance
VCC Pin −0.3 V to +6 V
Package Type θJA Unit
All INx+ and INx− Pins −0.3 V to +6 V 8-Lead Narrow-Body SOIC 121 °C/W All OUTx Pins −0.3 V to +6 V 14-Lead Narrow-Body SOIC 80 °C/W OUTx Pins Sink Current (ISINK) 10 mA 14-Lead TSSOP 125 °C/W Storage Temperature Range −65°C to +150°C Operating Temperature Range −40°C to +125°C Lead Temperature (10 sec) 300°C
ESD CAUTION
Junction Temperature 150°C Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. D | Page 4 of 17 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC COMPARATOR RAIL-TO-RAIL INPUT (RRI) OPEN-DRAIN OUTPUT POWER-UP BEHAVIOR CROSSOVER BIAS POINT COMPARATOR HYSTERESIS TYPICAL APPLICATIONS ADDING HYSTERESIS WINDOW COMPARATOR FOR POSITIVE VOLTAGE MONITORING WINDOW COMPARATOR FOR NEGATIVE VOLTAGE MONITORING PROGRAMMABLE SEQUENCING CONTROL CIRCUIT MIRRORED VOLTAGE SEQUENCER EXAMPLE THRESHOLD AND TIMEOUT PROGRAMMABLE VOLTAGE SUPERVISOR OUTLINE DIMENSIONS ORDERING GUIDE
