Datasheet ADCMP341, ADCMP343 (Analog Devices) - 9 Manufacturer Analog Devices Description Dual 0.275% Comparator and Reference with Programmable Hysteresis Pages / Page 12 / 9 — Data Sheet. ADCMP341/ADCMP343. 100. LH NON INV. A = 25°C. VDD = 5V. LH … Revision A File Format / Size PDF / 347 Kb Document Language English
Data Sheet. ADCMP341/ADCMP343. 100. LH NON INV. A = 25°C. VDD = 5V. LH INV. CL = 20pF. HL NON INV. HL INV. RISE. N DE. D F. AG P. 0.1. FALL. 0.01. 1000
Model Line for this Datasheet Text Version of Document Data Sheet ADCMP341/ADCMP343 60 100 T LH NON INV A = 25°C VDD = 5V LH INV CL = 20pF HL NON INV T 50 A = 25°C HL INV s) s) µ µ 10 ( ( Y S A 40 E L IM RISE T N DE L 30 L 1 IO A AT D F AG P 20 AN O E R S P RI 0.1 10 FALL 0 0.01 3 50 20 40 60 80 100 -020.1 1 10 100 1000 02 0- 00INPUT OVERDRIVE (mV) 50 65OUTPUT PULL-UP RESISTOR (kΩ) 0 06 Figure 24. Propagation Delay vs. Input Overdrive Figure 26. Rise and Fall Times vs. Output Pull-Up ResistorNON INV (OUTA) R1 = 22kΩ R2 = 2.2kΩ R3 = 6.2kΩ 2 INV (OUTB) OUTA 1 3 VIN (+INA, –INB) 1 VIN 2 26 0 4 0-CH1 50.0mV CH2 5.00V M20.0µs CH1 7mV 02 0-CH1 2.00V CH2 500mV M100ms 650 0CH3 5.00V 50 06 Figure 25. Noninverting and Inverting Comparators Propagation Delay Figure 27. Hysteresis Programmed to ~513 mV at Top of Input String (Hysteresis at ADCMP341 Pins ≈ 104 mV) Rev. A | Page 9 of 12 Document Outline Features Applications General Description Functional Block Diagrams Revision History Specifications Absolute Maximum Ratings Thermal Characteristics ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Application Information Comparators and Internal Reference Power Supply Inputs Outputs Programming Hysteresis Layout Recommendations Outline Dimensions Ordering Guide
