Datasheet ADCMP551, ADCMP552, ADCMP553 (Analog Devices) - 5
DescriptionSingle-Supply, High Speed PECL/LVPECL Comparators
Pages / Page15 / 5 — Data Sheet. ADCMP551/ADCMP552/ADCMP553. ABSOLUTE MAXIMUM RATINGS. THERMAL …
File Format / SizePDF / 204 Kb
Data Sheet. ADCMP551/ADCMP552/ADCMP553. ABSOLUTE MAXIMUM RATINGS. THERMAL CONSIDERATIONS. Table 2. Parameter Rating. ESD CAUTION
Data Sheet ADCMP551/ADCMP552/ADCMP553 ABSOLUTE MAXIMUM RATINGS THERMAL CONSIDERATIONS Table 2 Parameter Rating ESD CAUTION
Data Sheet ADCMP551/ADCMP552/ADCMP553 ABSOLUTE MAXIMUM RATINGS THERMAL CONSIDERATIONS Table 2.
The ADCMP551 16-lead QSOP package has a θ
Parameter Rating
JA (junction-to- ambient thermal resistance) of 104°C/W in still air. Supply Voltages Input Supply Voltage (VCCI to GND) −0.5 V to +6.0 V The ADCMP552 20-lead QSOP package has a θJA (junction-to- Output Supply Voltage (VCCO to GND) −0.5 V to +6.0 V ambient thermal resistance) of 80°C/W in still air. Ground Voltage Differential −0.5 V to +0.5 V The ADCMP553 8-lead MSOP package has a θJA (junction-to- Input Voltages ambient thermal resistance) of 130°C/W in still air. Input Common-Mode Voltage −0.5 V to +3.5 V Differential Input Voltage −4.0 V to +4.0 V Input Voltage, Latch Controls −0.5 V to +5.5 V
ESD CAUTION
Output Output Current 30 mA Temperature Operating Temperature, Ambient −40°C to +85°C Operating Temperature, Junction 125°C Storage Temperature Range −65°C to +150°C Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. B | Page 5 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CONSIDERATIONS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TIMING INFORMATION APPLICATIONS INFORMATION CLOCK TIMING RECOVERY OPTIMIZING HIGH SPEED PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
