Datasheet LT1716 (Analog Devices) - 7
Description | SOT-23, 44V, Over-The-Top, Micropower, Precision Rail-to-Rail Comparator |
Pages / Page | 14 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS. Input Bias Current. vs Common Mode … |
Revision | B |
File Format / Size | PDF / 416 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Input Bias Current. vs Common Mode Voltage. vs Temperature. vs Differential Input Voltage
LT1716
TYPICAL PERFORMANCE CHARACTERISTICS Input Bias Current Input Bias Current Input Bias Current vs Common Mode Voltage vs Temperature vs Differential Input Voltage
10 1.0000 1 VS = ±15V 125°C V+ = 15V V– = –15V 8 0.1000 V+ = 15V V– = –15V 0 25°C 85°C VCM = 0V V+ = 5V 6 0.0100 –IN +IN V– = 0V V –1 CM = 2.5V (µA) 4 –55°C 0.0010 CURRENT OUT OF PIN I BIAS CURRENT (nA) –2 2 0.0000 125°C I BIAS INPUT BIAS CURRENT (µA) CURRENT –3 TRANSITION 0 –0.0010 OUT OF PIN REGION INPUTS EXCEED SUPPLY –2 –0.0100 –4 0 5 10 15 20 25 30 –50 –25 0 25 50 75 100 125 150 –0.2 –0.15 –0.1 –0.05 0 0.05 0.1 0.15 0.2 VCM (V) TEMPERATURE (°C) DIFFERENTIAL INPUT VOLTAGE (V) 1716 G01 1716 G02 1716 G03
Output Low Voltage Output High Voltage Input Bias Current with Inputs vs Sink Current vs Source Current Driven Above the Supply
2.0 5.0 10 V+ = 5V V+ = 5V + ) (V) V– = 0V V V– = 0V OL AT 125°C 1.6 8 4.9 125°C VOH AT –55°C VOL AT 85°C 6 85°C 1.2 4.8 VOH AT 85°C, 125°C VOL AT 25°C V (µA) OH AT 25°C 4 –55°C 0.8 4.7 I BIAS 25°C VOL AT –55°C 2 0.4 4.6 0 V+ = 5V INPUTS OUTPUT VOLTAGE (RELATIVE TO GND) (V) V– = 0V EXCEED SUPPLY 0 OUTPUT HIGH VOLTAGE (RELATIVE TO V 4.5 –2 0 2 4 6 8 10 12 14 16 18 20 0 5 10 15 20 25 30 35 40 45 50 0 5 10 15 20 25 30 35 40 45 50 LOADING SINK CURRENT (mA) LOADING SOURCE CURRENT (µA) VCM (V) 1716 G04 1716 G05 1716 G06
Input Bias Current with Inputs Positive Supply Current Driven Below the Supply Supply Current vs Temperature vs Output Sinking Current
200 100 1000 V+ = 2.7V TO 44V V+ = 5V TA = 25°C V– = 0V 90 0 V– = 0V 80 –200 70 –55°C < TA < 125°C OUTPUT LOW –400 60 VS = ±15V VS = 5V (µA) 50 100 I BIAS –600 40 OUTPUT HIGH –800 30 SUPPLY CURRENT (µA) 20 –1000 POSITIVE SUPPLY CURRENT (µA) 10 –1200 0 10 –5 –4 –3 –2 –1 0 –50 –25 0 25 50 75 100 125 150 0.1 1 10 100 VCM (V) TEMPERATURE (°C) OUTPUT SINK CURRENT (mA) 1716 G07 1716 G08 1716 G09 Rev. B For more information www.analog.com 7 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Package Description Revision History Typical ApplicationS Related Parts
