Datasheet HMC675LP3E (Analog Devices) - 2
Description10 GHz Latched Comparator with RSCML Output Stage
Pages / Page10 / 2 — HMC675LP3E. 10 GHz LATCHED COMPARATOR. WITH RSCML OUTPUT STAGE. Latch …
File Format / SizePDF / 556 Kb
HMC675LP3E. 10 GHz LATCHED COMPARATOR. WITH RSCML OUTPUT STAGE. Latch Enable Characteristics
HMC675LP3E 10 GHz LATCHED COMPARATOR WITH RSCML OUTPUT STAGE Latch Enable Characteristics
HMC675LP3E
v02.0312
Parameter Conditions Min. Typ. Max Units Latch Enable Input Impedance Each Pin 8 KΩ T Latch Enable to Output Delay, tPLOL, tPLOH VOD = 200 mV 85 ps M Latch Enable Minimum Pulse Width, tPL VOD = 200 mV 20 ps Latch Enable Input Range VOD = 200 mV 1.6 2.4 V Latch Setup Time, tS VOD = 200 mV 45 ps S - S Latch Hold Time, tH -42 ps R O
DC Output Characteristics, with 50 Ω to GND
AT Parameter Conditions Min. Typ. Max Units R Output Voltage High Level, Voh -10 0 mV A Output Voltage Low Level, Vol -420 -400 -380 mV P Output Voltage Differential Swing 410 400 380 mV OM
AC Performance
C Parameter Conditions Min. Typ. Max Units Propagation Delay - tPD, tPDL, tPDH VOD = 500 mV 70 100 130 ps Propagation Delay, Temperature Coefficient 0.45 ps / °C Propagation Delay Skew VOD - 500 mV 10 ps (Rising to Falling Transition) VOD Dispersion 50 mV < VOD < 1 V 10 ps tPD vs. Common Mode Dispersion, VOD = 500 mV 3 ps -1.75 V <Vcm <1.75 V Noise (RTI) 3.2 nV/√(Hz) RTI Equivalent Input Bandwidth [1] 8.5 10 10.5 GHz Deterministic Jitter at 10 Gbps Deterministic Jitter (pp) 2 ps with ±100 mV Overdrive Random Jitter at 10 Gbps Random Jitter (rms) 0.2 ps rms with ±100 mV Overdrive Input Signal Minimum Pulse Width 60 ps Q / QB Rise Time From 20% to 80% 27 ps Q / QB Fall Time From 20% to 80% 18 ps
Power Supply Requirements
Parameter Conditions Min. Typ. Max Units Input Supply Current, Icci 9 mA Output Supply Current, Icco 8 mA Vee Current, lee 24 mA Power Dissipation, Pd 100 mW PSRR, Vcci 35 dB PSRR, Vee 35 dB Note 1: Equivalent Input Bandwidth is calculated with the following formula: Bweq=0.22/√ (TRCOMP2-TRIN2) where TRIN is the 20%/80% transition time of a quasi-Gaussian signal applied to the comparator input, and TRCOMP is the effective transition time digitized by the comparator. I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
2
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p o plic ra a tio pp n S s u @ p h por ittti : Pte ho.c n om e: 1-800-ANALOG-D
