Datasheet HMC674LC3C, HMC674LP3E (Analog Devices) - 6
Description9.3 GHz Latched Comparator with RSPECL Output Stage
Pages / Page14 / 6 — HMC674LC3C/HMC674LP3E. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 7. …
RevisionK
File Format / SizePDF / 331 Kb
HMC674LC3C/HMC674LP3E. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 7. Parameter. Rating. ESD CAUTION
HMC674LC3C/HMC674LP3E Data Sheet ABSOLUTE MAXIMUM RATINGS Table 7 Parameter Rating ESD CAUTION
link to page 13
HMC674LC3C/HMC674LP3E Data Sheet ABSOLUTE MAXIMUM RATINGS Table 7.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these Supply Voltage or any other conditions above those indicated in the operational Input (VCCI to GND) −0.5 V to +4 V section of this specification is not implied. Operation beyond Output (VCCO to GND) −0.5 V to +4 V the maximum operating conditions for extended periods may Positive Differential (VCCI to VCCO) −0.5 V to +3.3 V affect product reliability. VEE Supply to GND −3.3 V to +0.5 V Input Voltage −2 V to +2 V Differential −2 V to +2 V
ESD CAUTION
Latch Enable (LE/LE) −0.5 V to VCCI + 0.5 V Applied Voltage (HYS) VEE to GND Current Maximum Input ±20 mA Output 40 mA Continuous Power Dissipation (P DISS), TA = 85°C Derate 43.5 mW/°C Above 85°C 1.74 W (HMC674LP3E) Derate 20.4 mW/°C Above 85°C 0.816 W (HMC674LC3C) Junction Temperature 125°C Maximum Peak Reflow Temperature1 MSL1 and MSL3 260°C Thermal Resistance (θJC) HMC674LP3E 23°C/W HMC674LC3C 49°C/W Storage Temperature Range −65°C to +150°C Operating Temperature Range −40°C to +85°C ESD Sensitivity, Human Body Model (HBM) Class 1A 1 See the Ordering Guide section. Rev. K | Page 6 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS LATCH ENABLE (LE/) SPECIFICATIONS DC OUTPUT SPECIFICATIONS AC SPECIFICATIONS POWER SUPPLY SPECIFICATIONS TIMING DESCRIPTIONS Timing Diagram ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION POWER SEQUENCING APPLICATIONS INFORMATION EVALUATION PRINTED CIRCUIT BOARD (PCB) APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
