Datasheet ADCMP604, ADCMP605 (Analog Devices) - 6
DescriptionRail-to-Rail, Very Fast, 2.5 V to 5.5 V, Single-Supply LVDS Comparators
Pages / Page14 / 6 — ADCMP604/ADCMP605. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL …
RevisionC
File Format / SizePDF / 357 Kb
ADCMP604/ADCMP605. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE. Parameter. Rating. Table 4. Thermal Resistance
ADCMP604/ADCMP605 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3 THERMAL RESISTANCE Parameter Rating Table 4 Thermal Resistance
ADCMP604/ADCMP605 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE Parameter Rating
θJA is specified for the worst-case conditions, that is, a device Supply Voltages soldered in a circuit board for surface-mount packages. Input Supply Voltage (VCCI to GND) −0.5 V to +6.0 V Output Supply Voltage (V
CCO to GND) −0.5 V to +6.0 V
1
Positive Supply Differential (V
Package Type θJA Unit
CCI − VCCO) −6.0 V to +6.0 V Input Voltages 6-Lead SC70 (KS-6) 426 °C/W Input Voltage −0.5 V to V 12-Lead LFCSP_VQ (CP-12-1) 62 °C/W CCI + 0.5 V Differential Input Voltage ±(V 1 CCI + 0.5 V) Measurement in stil air. Maximum Input/Output Current ±50 mA Shutdown Control Pin
ESD CAUTION
Applied Voltage (SDN to GND) −0.5 V to VCCO + 0.5 V Maximum Input/Output Current ±50 mA Latch/Hysteresis Control Pin Applied Voltage (HYS to GND) −0.5 V to VCCO + 0.5 V Maximum Input/Output Current ±50 mA Output Current ±50 mA Temperature Operating Temperature Range, Ambient −40°C to +125°C Operating Temperature, Junction 150°C Storage Temperature Range −65°C to +150°C Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. C | Page 6 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS TIMING INFORMATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION POWER/GROUND LAYOUT AND BYPASSING LVDS-COMPATIBLE OUTPUT STAGE USING/DISABLING THE LATCH FEATURE OPTIMIZING PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS CROSSOVER BIAS POINTS MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
