Datasheet ADCMP604, ADCMP605 (Analog Devices) - 8
DescriptionRail-to-Rail, Very Fast, 2.5 V to 5.5 V, Single-Supply LVDS Comparators
Pages / Page14 / 8 — ADCMP604/ADCMP605. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 800. …
RevisionC
File Format / SizePDF / 357 Kb
ADCMP604/ADCMP605. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 800. 1.60. 600. 1.50. OUTPUT HI. 400. 1.40. CC = 2.5V. CC = 5.5V. 200. µ (
ADCMP604/ADCMP605 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 800 1.60 600 1.50 OUTPUT HI 400 1.40 CC = 2.5V CC = 5.5V 200 µ (
VCCI = VCCO = 2.5 V, TA = 25°C, unless otherwise noted.
800 1.60 600 1.50 OUTPUT HI 400 V V 1.40 CC = 2.5V CC = 5.5V A) 200 µ ( (V) 1.30 T OUTPUT VCM NT 0 PU T 1.20 U O CURRE –200 1.10 –400 OUTPUT LO 1.00 –600 –800 0.90
011
–1 0 1 2 3 4 5 6 7
010
2.4 2.9 3.4 3.9 4.4 4.9 5.4 5.9 LE/HYS PIN (V) V
05916-
CCO (V)
05916- Figure 5. LE/HYS Pin Current vs. Voltage Figure 8. LVDS Output Level vs. VCCO (V)
200 850 800 150 750 100 V V 700 ) A) CC = 2.5V CC = 5.5V µ ps +125°C ( 50 650 NT LL ( 0 /FA 600 E CURRE IS R +25°C 550 –50 –40°C 500 –100 450 –150 400 –1 0 1 2 3 4 5 6 7
006
2.40 2.80 3.20 3.60 4.00 4.40 4.80 5.20 5.60 6.00
007
SDN PIN (V)
05916-
VCCO (V)
05916- Figure 6. SDN Pin Current vs. Voltage Figure 9. LVDS Output Rise/Fall Time vs. VCCO (V)
10 250 +125°C 8 +25°C 6 200 4 –40°C V) 2 150 S (m A) µ 0 ( ESI I B ER –2 100 YST H –4 VCC = 2.5V –6 50 –8 VCC = 5.5V –10 0 –1.0 –0.5 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5
009
50 100 150 200 250 300 350 400 450 500
008
VCM AT VCC = 2.5V HYSTERESIS RESISTOR (kΩ)
05916- 05916- Figure 10. Hysteresis vs. Hysteresis Resistor Figure 7. Input Bias Current vs. Input Common-Mode Voltage Rev. C | Page 8 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS TIMING INFORMATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION POWER/GROUND LAYOUT AND BYPASSING LVDS-COMPATIBLE OUTPUT STAGE USING/DISABLING THE LATCH FEATURE OPTIMIZING PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS CROSSOVER BIAS POINTS MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
