Datasheet AD8564 (Analog Devices) - 6 Manufacturer Analog Devices Description Quad 7 ns Single Supply Comparator Pages / Page 12 / 6 — AD8564. TYPICAL PERFORMANCE CHARACTERISTICS. 1.0. 500. 0.8. 400. (mV). G … Revision B File Format / Size PDF / 275 Kb Document Language English
AD8564. TYPICAL PERFORMANCE CHARACTERISTICS. 1.0. 500. 0.8. 400. (mV). G A. T 0.6. L 300. AM F. ET S F 0.4. R O 200. IN 0.2. 100. –75. –50. –25. 125. 150
Model Line for this Datasheet Text Version of Document AD8564 TYPICAL PERFORMANCE CHARACTERISTICS V+ANA = V+DIG = 5 V, V–ANA = 0 V, TA = 25°C, unless otherwise noted.1.0 500 0.8 400 (mV) RS E IE G A IF T 0.6 L 300 L P VO AM F ET S F 0.4 R O 200 F E O B T M PU NU IN 0.2 100 0 0 04 07–75 –50 –25 0 25 50 75 100 125 150 0–5 –4 –3 –2 –1 0 1 2 3 4 5 0 3- 3-TEMPERATURE (°C) 10 1 10 0INPUT OFFSET VOLTAGE (mV) 01 Figure 4. Input Offset Voltage vs. Temperature Figure 7. Input Offset Voltage Distribution0 10 STEPSIZE = 100mV OVERDRIVE = 5mV –1 8 A) s) n (µ tPDHL Y ( NT A –2 L 6 E D tPDLH CURRE TION AS –3 A 4 BI G A UT P O INP PR –4 2 –5 50 8–75 –50 –25 0 25 50 75 100 125 150 00 00 3-–50 –25 0 25 50 75 100 125 3-TEMPERATURE (°C) 10 1 10 0TEMPERATURE (°C) 1 0 Figure 5. Input Bias Current vs. Temperature Figure 8. Propagation Delay, tPDHL/tPDLH vs. Temperature0 5.0 V+ANA = V+DIG = +5V V–ANA = –5V –1 ) 4.4 V A) m TA = +85°C (µ ( E NT –2 AG T 3.8 RE L O TA = +25°C V CUR H AS G –3 3.2 BI HI UT UT P INP UT TA = –40°C –4 O 2.6 –5 2.0 06 09–7.5 –5.0 –2.5 0 2.5 5.0 0 0 3-0 3 6 9 12 15 3-INPUT COMMON-MODE VOLTAGE (V) 10 10 01SOURCE CURRENT (mA) 01 Figure 6. Input Bias Current vs. Input Common-Mode Voltage Figure 9. Output High Voltage, VOH vs. Source Current Rev. B | Page 6 of 12 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION OPTIMIZING HIGH SPEED PERFORMANCE OUTPUT LOADING CONSIDERATIONS INPUT STAGE AND BIAS CURRENTS USING HYSTERESIS OUTLINE DIMENSIONS ORDERING GUIDE
