Datasheet LT1016 (Analog Devices) - 5
Description | UltraFast Precision 10ns Comparator |
Pages / Page | 22 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS. Negative Supply Current vs. Positive … |
Revision | D |
File Format / Size | PDF / 1.0 Mb |
TYPICAL PERFORMANCE CHARACTERISTICS. Negative Supply Current vs. Positive Supply Current vs. Temperature
LT1016
TYPICAL PERFORMANCE CHARACTERISTICS Negative Supply Current vs Positive Supply Current vs Positive Supply Current vs Temperature Positive Supply Voltage Switching Frequency
6 50 40 VS = ±5V V– = 0V TJ = 125°C IOUT = 0 45 VIN = 60mV 35 T 5 J = 25°C 40 IOUT = 0 TJ = –55°C 30 35 4 30 25 3 25 20 20 CURRENT (mA) 15 2 CURRENT (mA) CURRENT (mA) 15 TJ = 25°C TJ = 125°C 10 10 1 VS = 5V 5 5 T VIN = 50mV J = – 55°C IOUT = 0 0 0 0 –50 –25 0 25 50 75 100 125 0 1 2 3 4 5 6 7 8 1 10 100 JUNCTION TEMPERATURE (°C) SUPPLY VOLTAGE (V) SWITCHING FREQUENCY (MHz) 1016 G10 1016 G11 1016 G12
Common Mode Rejection vs Positive Common Mode Limit vs Negative Common Mode Limit vs Frequency Temperature Temperature
120 6 2 VS = ±5V VS = ±5V* 110 V V IN = 2VP-P S = SINGLE 5V SUPPLY TJ = 25°C 5 1 100 4 0 90 *SEE APPLICATION INFORMATION 80 3 –1 FOR COMMON MODE LIMIT WITH VARYING SUPPLY VOLTAGE. 70 INPUT VOLTAGE (V) 2 INPUT VOLTAGE (V) –2 REJECTION RATIO (dB) 60 1 *SEE APPLICATION INFORMATION –3 50 FOR COMMON MODE LIMIT WITH VARYING SUPPLY VOLTAGE. VS = ±5V* 40 0 –4 10k 100k 1M 10M –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 FREQUENCY (Hz) JUNCTION TEMPERATURE (°C) JUNCTION TEMPERATURE (°C) 1016 G13 1016 G14 1016 G15
LATCH Pin Threshold vs LATCH Pin Current* vs Temperature Temperature
2.6 300 VS = ±5V VS = ±5V V 2.2 LATCH = 0V 250 1.8 200 OUTPUT LATCHED 1.4 150 VOLTAGE (V) OUTPUT UNAFFECTED CURRENT (A) 1.0 100 0.6 50 *CURRENT COMES OUT OF LATCH PIN BELOW THRESHOLD 0.2 0 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 JUNCTION TEMPERATURE (°C) JUNCTION TEMPERATURE (°C) 1016 G16 1016 G17 Rev D For more information www.analog.com 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Typical Applications Appendix A Package Description Revision History Applications Information Related Parts
