Datasheet ADP7182 (Analog Devices) - 8
Description–28 V, −200 mA, Low Noise, Linear Regulator
Pages / Page32 / 8 — ADP7182. Data Sheet. VOUT 1. 8 VIN. VOUT 2. 7 VIN. TOP VIEW. NC 3. (Not …
RevisionM
File Format / SizePDF / 964 Kb
ADP7182. Data Sheet. VOUT 1. 8 VIN. VOUT 2. 7 VIN. TOP VIEW. NC 3. (Not to Scale). 6 GND. ADJ 3. EXPOSED PAD. EN 4. 5 NC. NOTES
ADP7182 Data Sheet VOUT 1 8 VIN VOUT 2 7 VIN TOP VIEW NC 3 (Not to Scale) 6 GND ADJ 3 EXPOSED PAD EN 4 5 NC NOTES
ADP7182 Data Sheet VOUT 1 8 VIN VOUT 1 8 VIN VOUT 2 ADP7182 7 VIN VOUT 2 ADP7182 7 VIN TOP VIEW TOP VIEW NC 3 (Not to Scale) 6 GND ADJ 3 (Not to Scale) 6 GND EXPOSED PAD EN 4 5 NC EXPOSED PAD EN 4 5 NC NOTES NOTES 1. NC = NO CONNECT. DO NOT CONNECT TO THIS PIN. 1. NC = NO CONNECT. DO NOT CONNECT TO THIS PIN. 2. THE EXPOSED PAD ON THE BOTTOM OF THE LFCSP PACKAGE ENHANCES 2. THE EXPOSED PAD ON THE BOTTOM OF THE LFCSP PACKAGE ENHANCES THERMAL PERFORMANCE AND IS ELECTRICALLY CONNECTED TO VIN THERMAL PERFORMANCE AND IS ELECTRICALLY CONNECTED TO VIN INSIDE THE PACKAGE. THE EXPOSED PAD MUST BE CONNECTED TO THE INSIDE THE PACKAGE. THE EXPOSED PAD MUST BE CONNECTED TO THE
5
VIN PLANE ON THE BOARD FOR PROPER OPERATION. BECAUSE THIS IS A VIN PLANE ON THE BOARD FOR PROPER OPERATION. BECAUSE THIS IS A
06 -00 0
NEGATIVE VOLTAGE REGULATOR, VIN IS THE MOST NEGATIVE POTENTIAL NEGATIVE VOLTAGE REGULATOR, VIN IS THE MOST NEGATIVE POTENTIAL
3- 03
IN THE CIRCUIT.
70
IN THE CIRCUIT.
107 10 Figure 5. 8-Lead LFCSP Pin Configuration, Fixed Output Voltage Figure 6. 8-Lead LFCSP Pin Configuration, Adjustable Output Voltage
Table 6. 8-Lead LFCSP Pin Function Descriptions LFCSP Pin No. Fixed Output Voltage Adjustable Output Voltage Mnemonic Description
1, 2 1, 2 VOUT Regulated Output Voltage. Bypass VOUT to GND with a 2.2 μF or greater capacitor. Not Applicable 3 ADJ Adjustable Input. An external resistor divider sets the output voltage. 3 Not applicable NC No Connect. Do not connect to this pin. 4 4 EN Drive EN 2 V above or below ground to enable the regulator, or drive EN to ground to turn off the regulator. For automatic startup, connect EN to VIN. 5 5 NC No Connect. Do not connect to this pin. 6 6 GND Ground. 7, 8 7, 8 VIN Regulator Input Supply. Bypass VIN to GND with a 2.2 μF or greater capacitor. 9 9 EPAD Exposed pad. The exposed pad on the bottom of the LFCSP package enhances thermal performance and is electrically connected to VIN inside the package. The exposed pad must be connected to the VIN plane on the board for proper operation. Because this is a negative voltage regulator, VIN is the most negative potential in the circuit. Rev. M | Page 8 of 32 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUITS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS INPUT AND OUTPUT CAPACITANCE, RECOMMENDED SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL DATA THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ADJUSTABLE MODE OPERATION APPLICATIONS INFORMATION ADIsimPower DESIGN TOOL CAPACITOR SELECTION Output Capacitor Input Bypass Capacitor Input and Output Capacitor Properties ENABLE PIN OPERATION SOFT START NOISE REDUCTION OF THE ADJUSTABLE ADP7182 CURRENT-LIMIT AND THERMAL OVERLOAD PROTECTION THERMAL CONSIDERATIONS Thermal Characterization Parameter, ΨJB PCB LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
