ADP7156Data Sheet0010Hz10Hz 100Hz–10100Hz–101kHz1kHz 10kHz–2010kHz–20100kHz100kHz1MHz1MHz–30–3010MHz10MHz–40–40B)B)dd–50–50RR (RR (SSP–60P–60–70–70–80–80–90–90–100–1000.50.60.70.80.9 023 0.50.60.70.80.9 026 HEADROOM VOLTAGE (V) 12937- HEADROOM VOLTAGE (V) 12937- Figure 23. Power Supply Rejection Ratio (PSRR) vs. Headroom Voltage Figure 26. Power Supply Rejection Ratio (PSRR) vs. Headroom Voltage at Various Frequencies, VOUT = 3.3 V, 1.2 A Load at Various Frequencies, VOUT = 1.8 V, 1.2 A Load 00I–10LOAD = 10mA–10ILOAD = 100mA ICBYP = 1µF–20LOAD = 600mA–20ICLOAD = 1200mABYP = 10µFCBYP = 100µF–30–30CBYP = 1000µF–40–40B)B)dd–50–50RR (RR (SSP–60P–60–70–70–80–80–90–90–100–1001101001k10k100k1M10M 024 1101001k10k100k1M10M 027 FREQUENCY (Hz) 12937- FREQUENCY (Hz) 12937- Figure 24. Power Supply Rejection Ratio (PSRR) vs. Frequency Figure 27. Power Supply Rejection Ratio (PSRR) vs. Frequency at Various Loads, VOUT = 1.8 V, VIN = 2.6 V at Various CBYP Values, VOUT = 3.3 V, VIN = 4.0 V, 1.2 A Load 02.0–101.810Hz TO 100kHz–201.6900mV–30800mV1.4rms)700mVV–40µ 1.2B)600mV(d500mVE–50IS 1.0RR (100Hz TO 100kHzSNOP–600.8UT P–70UT 0.6O–800.4–900.2–10001101001k10k100k1M10M 025 10m100m110 028 FREQUENCY (Hz) 12937- LOAD CURRENT (A) 12937- Figure 25. Power Supply Rejection Ratio (PSRR) vs. Frequency Figure 28. RMS Output Noise vs. Load Current at Various Headroom Voltages, VOUT = 1.8 V, 1.2 A Load Rev. B | Page 10 of 22 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TYPICAL APPLICATION CIRCUIT REVISION HISTORY SPECIFICATIONS INPUT AND OUTPUT CAPACITORS, RECOMMENDED SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL DATA THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION ADIsimPOWER DESIGN TOOL CAPACITOR SELECTION Output Capacitor Input and VREG Capacitor REF Capacitor BYP Capacitor Capacitor Properties UNDERVOLTAGE LOCKOUT (UVLO) PROGRAMMABLE PRECISION ENABLE START-UP TIME REF, BYP, AND VREG PINS CURRENT-LIMIT AND THERMAL SHUTDOWN THERMAL CONSIDERATIONS Thermal Characterization Parameter (ΨJB) PRINTED CIRCUIT BOARD (PCB) LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
