Datasheet ADP1762 (Analog Devices)
Description | 2 A, Low VIN, Low Noise, CMOS Linear Regulator |
Pages / Page | 18 / 1 — 2 A, Low VIN, Low Noise,. CMOS Linear Regulator. Data Sheet. ADP1762. … |
Revision | C |
File Format / Size | PDF / 928 Kb |
2 A, Low VIN, Low Noise,. CMOS Linear Regulator. Data Sheet. ADP1762. FEATURES. TYPICAL APPLICATION CIRCUITS
2 A, Low VIN, Low Noise, CMOS Linear Regulator Data Sheet ADP1762 FEATURES TYPICAL APPLICATION CIRCUITS 2 A maximum output current ADP1762 V V IN = 1.7V OUT = 1.5V Low input voltage supply range VIN VOUT C C IN OUT V 10µF 10µF IN = 1.10 V to 1.98 V, no external bias supply required SENSE Fixed output voltage range: V R OUT_FIXED = 0.9 V to 1.5 V PULL-UP ON 100kΩ EN Adjustable output voltage range: V OFF OUT_ADJ = 0.5 V to 1.5 V PG PG Ultralow noise: 2 μV rms, 100 Hz to 100 kHz SS VADJ Noise spectral density CSS VREG REFCAP 10nF 4 nV/√Hz at 10 kHz C C
1
REG GND REF
00
1µF 1µF
22-
3 nV/√Hz at 100 kHz
129
Low dropout voltage: 62 mV typical at 2 A load
Figure 1. Fixed Output Operation
Operating supply current: 4.5 mA typical at no load ADP1762 ±1.5% fixed output voltage accuracy over line, load, and V V IN = 1.7V OUT = 1.5V VIN VOUT C C temperature IN OUT 10µF 10µF SENSE Excellent power supply rejection ratio (PSRR) performance RPULL-UP ON 62 dB typical at 10 kHz at 2 A load 100kΩ EN PG PG OFF 46 dB typical at 100 kHz at 2 A load SS VADJ Excellent load/line transient response CSS VREG REFCAP RADJ Soft start to reduce inrush current 10nF C C 10kΩ REG GND REF 1µF
002
Optimized for small 10 μF ceramic capacitors 1µF
922- 12
Current-limit and thermal overload protection
Figure 2. Adjustable Output Operation
Power-good indicator Precision enable Table 1. Related Devices 16-lead, 3 mm × 3 mm LFCSP package Input Maximum Fixed/ Device Voltage Current Adjustable Package APPLICATIONS
ADP1761 1.10 V to 1 A Fixed/adjustable 16-lead
Regulation to noise sensitive applications such as radio
1.98 V LFCSP
frequency (RF) transceivers, analog-to-digital converter
ADP1763 1.10 V to 3 A Fixed/adjustable 16-lead
(ADC) and digital-to-analog converter (DAC) circuits,
1.98 V LFCSP
phase-locked loops (PLLs), voltage controlled oscillators
ADP1740/ 1.6 V to 2 A Fixed/adjustable 16-lead ADP1741 3.6 V LFCSP
(VCOs) and clocking integrated circuits
ADP1752/ 1.6 V to 0.8 A Fixed/adjustable 16-lead
Field-programmable gate array (FPGA) and digital signal
ADP1753 3.6 V LFCSP
processor (DSP) supplies
ADP1754/ 1.6 V to 1.2 A Fixed/adjustable 16-lead
Medical and healthcare
ADP1755 3.6 V LFCSP
Industrial and instrumentation
The ADP1762 is optimized for stable operation with small 10 μF
GENERAL DESCRIPTION
ceramic output capacitors. The ADP1762 delivers optimal The ADP1762 is a low noise, low dropout (LDO) linear regulator. transient performance with minimal board area. It is designed to operate from a single input supply with an input The ADP1762 is available in fixed output voltages ranging from voltage as low as 1.10 V, without the requirement of an external 0.9 V to 1.5 V. The output of the adjustable output model can bias supply, to increase efficiency and provide up to 2 A of be set from 0.5 V to 1.5 V through an external resistor connected output current. between VADJ and ground. The low 62 mV typical dropout voltage at a 2 A load allows the The ADP1762 has an externally programmable soft start time by ADP1762 to operate with a small headroom while maintaining connecting a capacitor to the SS pin. Short-circuit and thermal regulation and providing better efficiency. overload protection circuits prevent damage in adverse conditions. The ADP1762 is available in a small 16-lead LFCSP package for the smallest footprint solution to meet a variety of applications.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. No license is granted by implication or otherwise under any patent or patent rights of Analog Tel: 781.329.4700 ©2016–2020 Analog Devices, Inc. All rights reserved. Devices. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Typical Application Circuits Revision History Specifications Input and Output Capacitor: Recommended Specifications Absolute Maximum Ratings Thermal Data Thermal Resistance/Parameter ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Soft Start Function Adjustable Output Voltage Enable Feature Power-Good (PG) Feature Applications Information Capacitor Selection Output Capacitor Input Bypass Capacitor Input and Output Capacitor Properties Undervoltage Lockout Current-Limit and Thermal Overload Protection Thermal Considerations PCB Layout Considerations Outline Dimensions Ordering Guide
