Datasheet LT3066 (Analog Devices) - 6
Description | 45V VIN, 500mA Low Noise, Linear Regulator with Programmable Current Limit and Active Output Discharge |
Pages / Page | 26 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS TJ = 25°C, unless otherwise noted. … |
Revision | B |
File Format / Size | PDF / 2.0 Mb |
TYPICAL PERFORMANCE CHARACTERISTICS TJ = 25°C, unless otherwise noted. Quiescent Current. LT3066-3.3 GND Pin Current
LT3066 Series
TYPICAL PERFORMANCE CHARACTERISTICS TJ = 25°C, unless otherwise noted. Quiescent Current LT3066-3.3 GND Pin Current LT3066-5 GND Pin Current
130 24 24 TJ = 25°C R 120 R T L = 6.6Ω J = 25°C L = 10Ω TJ = 25°C V 22 22 OUT = 5V I *FOR V L = 500mA* OUT = 3.3V IL = 500mA* *FOR VOUT = 5V 110 IL = 10µA 20 VSHDN = VIN 20 VSHDN = VIN 100 18 18 90 R 16 16 L = 20Ω 80 IL = 250mA* 14 14 70 V R R SHDN = VIN L = 33Ω L = 50Ω 12 IL = 100mA* 12 I 60 L = 100mA* 50 10 10 RL = 13.2Ω 40 8 I 8 R L = 250mA* RL = 330Ω L = 500Ω I IL = 10mA* QUIESCENT CURRENT (µA) 30 GND PIN CURRENT (mA) 6 L = 10mA* GND PIN CURRENT (mA) 6 20 4 4 10 V 2 2 SHDN = 0V 0 0 0 0 5 10 15 20 25 30 35 40 45 0 1 2 3 4 5 6 7 8 9 10 11 12 0 1 2 3 4 5 6 7 8 9 10 11 12 VIN (V) INPUT VOLTAGE (V) INPUT VOLTAGE (V) 3066 G10 3066 G11 3066 G12
GND Pin Current vs ILOAD SHDN Pin Threshold
20 1.5 V 18 IN = 5.6V 1.4 OFF TO ON VOUT = 5V 1.3 16 1.2 14 1.1 1.0 ON TO OFF 12 0.9 10 0.8 0.7 8 PIN THRESHOLD (V) 0.6 6 0.5 GND PIN CURRENT (mA) 0.4 4 SHDN 0.3 2 0.2 0.1 0 0 0 50 100 150 200 250 300 350 400 450 500 –75 –50 –25 0 25 50 75 100 125 150 175 ILOAD (mA) TEMPERATURE (°C) 3066 G13 3066 G14
SHDN Pin Current SHDN SHDN Pin Input Current SHDN
3.0 3.0 SHDN = 45V 2.5 2.5 2.0 2.0 1.5 1.5 PIN CURRENT (µA) PIN CURRENT (µA) 1.0 1.0 SHDN SHDN 0.5 0.5 0 0 –75 –50 –25 0 25 50 75 100 125 150 175 0 5 10 15 20 25 30 35 40 45 TEMPERATURE (°C) SHDN PIN VOLTAGE (V) 3066 G16 3066 G15 Rev. B 6 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
