Datasheet ADP7118 (Analog Devices) - 4
Description20 V, 200 mA, Low Noise, CMOS LDO Linear Regulator
Pages / Page24 / 4 — ADP7118. Data Sheet. INPUT AND OUTPUT CAPACITANCE, RECOMMENDED …
RevisionE
ADP7118. Data Sheet. INPUT AND OUTPUT CAPACITANCE, RECOMMENDED SPECIFICATIONS. Table 2. Parameter. Symbol
ADP7118 Data Sheet INPUT AND OUTPUT CAPACITANCE, RECOMMENDED SPECIFICATIONS Table 2 Parameter Symbol
ADP7118 Data Sheet INPUT AND OUTPUT CAPACITANCE, RECOMMENDED SPECIFICATIONS Table 2. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
INPUT AND OUTPUT CAPACITANCE Minimum Capacitance1 CMIN TA = −40°C to +125°C 1.5 μF Capacitor Effective Series Resistance (ESR) RESR TA = −40°C to +125°C 0.001 0.3 Ω 1 The minimum input and output capacitance must be greater than 1.5 μF over the full range of operating conditions. The full range of operating conditions in the application must be considered during device selection to ensure that the minimum capacitance specification is met. X7R and X5R type capacitors are recommended, while Y5V and Z5U capacitors are not recommended for use with any LDO. Rev. E | Page 4 of 24 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUITS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS INPUT AND OUTPUT CAPACITANCE, RECOMMENDED SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL DATA THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION ADIsimPOWER DESIGN TOOL CAPACITOR SELECTION Output Capacitor Input Bypass Capacitor Input and Output Capacitor Properties PROGRAMABLE PRECISION ENABLE SOFT START NOISE REDUCTION OF THE ADP7118 IN ADJUSTABLE MODE EFFECT OF NOISE REDUCTION ON START-UP TIME CURRENT-LIMIT AND THERMAL OVERLOAD PROTECTION THERMAL CONSIDERATIONS PRINTED CIRCUIT BOARD LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
