Datasheet ADP165, ADP166 (Analog Devices) - 3
Description | Very Low Quiescent Current, 150 mA, LDO Regulator |
Pages / Page | 23 / 3 — Data Sheet. ADP165/ADP166. SPECIFICATIONS. Table 1. Parameter. Symbol. … |
Revision | A |
File Format / Size | PDF / 613 Kb |
Data Sheet. ADP165/ADP166. SPECIFICATIONS. Table 1. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
Data Sheet ADP165/ADP166 SPECIFICATIONS
VIN = (VOUT + 0.5 V) or 2.2 V, whichever is greater, EN = VIN, IOUT = 10 mA, CIN = COUT = 1 µF, TA = 25°C, TJ = −40°C to +125°C for minimum/maximum specifications, unless otherwise noted.
Table 1. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
INPUT VOLTAGE RANGE VIN TJ = −40°C to +125°C 2.2 5.5 V OPERATING SUPPLY CURRENT IQ IOUT = 0 µA, TA = 25°C 590 1250 nA IOUT = 0 µA, TJ = −40°C to +125°C 2.4 µA IOUT = 1 µA, TA = 25°C 890 1800 nA IOUT = 1 µA ,TJ = −40°C to +125°C 3.0 µA IOUT = 100 µA, TA = 25°C 2.6 4.8 µA IOUT = 100 µA, TJ = −40°C to +125°C 6.2 µA IOUT = 10 mA, TA = 25°C 11 19 µA IOUT = 150 mA , TA = 25°C 42 65 µA SUPPLY CURRENT IN DROPOUT IQ_DROP IOUT = 0 µA, VIN = VOUT − 0.2 V, TA = 25°C 720 1600 nA (PASS THROUGH MODE) IOUT = 0 µA, VIN = VOUT − 0.2 V, TJ = −40°C to +125°C 2.7 µA IOUT = 1 µA, VIN = VOUT − 0.2 V, TA = 25°C 1200 2400 nA IOUT = 1 µA, VIN = VOUT − 0.2 V, TJ = −40°C to +125°C 3.5 µA SHUTDOWN CURRENT IGND-SD EN = GND 50 nA EN = GND, TJ = −40°C to +125°C 1 µA FIXED OUTPUT VOLTAGE ACCURACY VOUT_ACCURACY IOUT = 10 mA, TA = 25°C −1 +1 % 0 µA < IOUT < 150 mA, VIN = (VOUT + 0.5 V) to 5.5 V, −2 +2 % TA = 25°C 0 µA < IOUT < 150 mA, VIN = (VOUT + 0.5 V) to 5.5 V, −3.5 +3.5 % TJ = −40°C to +125°C ADJ PIN VOLTAGE ACCURACY1 VADJ IOUT = 10 mA 0.99 1.0 1.01 V 0 µA < IOUT < 150 mA, VIN = (VOUT + 0.5 V) to 5.5 V 0.98 1.02 V 0 µA < IOUT < 150 mA, VIN = (VOUT + 0.5 V) to 5.5 V, 0.97 1.03 V TJ = −40°C to +125°C REGULATION Line Regulation ∆VOUT/∆VIN VIN = (VOUT + 0.5 V) to 5.5 V, TJ = −40°C to +125°C −0.1 +0.1 %/V Load Regulation2 ∆VOUT/∆IOUT IOUT = 100 µA to 150 mA 0.004 0.01 %/mA DROPOUT VOLTAGE3 VDROPOUT VOUT = 3.3 V IOUT = 10 mA 45 110 mV IOUT = 150 mA 120 225 mV ADJ PIN INPUT BIAS CURRENT ADJI-BIAS 2.2 V ≤ VIN ≤ 5.5 V, ADJ connected to VOUT 10 nA ACTIVE PULL-DOWN RESITANCE RPULL-DOWN VOUT = 3.3 V, RLOAD = ∞ 300 600 Ω (ADP165) START-UP TIME4 TSTART-UP VOUT = 3.3 V 1100 µs MAXIMUM OPERATING LOAD ILOAD_MAX 150 mA CURRENT CURRENT-LIMIT THRESHOLD5 ILIMIT 215 320 500 mA THERMAL SHUTDOWN Thermal Shutdown Threshold TSSD TJ rising 150 °C Thermal Shutdown Hysteresis TSSD-HYS 15 °C EN INPUT EN Input Logic High VIH 2.2 V ≤ VIN ≤ 5.5 V 1.2 V EN Input Logic Low VIL 2.2 V ≤ VIN ≤ 5.5 V 0.4 V EN Input Leakage Current VI-LEAKAGE EN = VIN or GND 0.1 µA EN = VIN or GND, TJ = −40°C to +125°C 1 µA Rev. A | Page 3 of 23 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUITS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS RECOMMENDED SPECIFICATIONS: INPUT AND OUTPUT CAPACITORS ABSOLUTE MAXIMUM RATINGS THERMAL DATA THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION CAPACITOR SELECTION Output Capacitor, COUT Input Bypass Capacitor, CIN Input and Output Capacitor Properties ENABLE FEATURE UNDERVOLTAGE LOCKOUT (UVLO) CURRENT-LIMIT AND THERMAL OVERLOAD PROTECTION THERMAL CONSIDERATIONS PCB LAYOUT CONSIDERATIONS LIGHT SENSITIVITY OF WLCSPs OUTLINE DIMENSIONS ORDERING GUIDE
