Datasheet ADP165, ADP166 (Analog Devices) - 6
DescriptionVery Low Quiescent Current, 150 mA, LDO Regulator
Pages / Page23 / 6 — ADP165/ADP166. Data Sheet. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. …
File Format / SizePDF / 613 Kb
ADP165/ADP166. Data Sheet. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. VIN 1. VOUT. ADP165/. ADP166. GND 2. TOP VIEW. (Not to Scale)
ADP165/ADP166 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS VIN 1 VOUT ADP165/ ADP166 GND 2 TOP VIEW (Not to Scale)
ADP165/ADP166 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS VIN 1 5 VOUT ADP165/ ADP166 GND 2 TOP VIEW (Not to Scale) EN 3 4 NC
004
NOTES 1. NC = NO CONNECT. NOT CONNECTED INTERNALLY.
12188- Figure 4. 5-Lead TSOT, Fixed Output Pin Configuration
Table 5. Fixed Output, 5-Lead TSOT Pin Function Descriptions Pin No. Mnemonic Description
1 VIN Regulator Input Supply. Bypass VIN to GND with a 1 µF or greater capacitor. 2 GND Ground. 3 EN Enable Input. Drive EN high to turn on the regulator; drive EN low to turn off the regulator. For automatic startup, connect EN to VIN. 4 NC No Connect. This pin is not connected internally. 5 VOUT Regulated Output Voltage. Bypass VOUT to GND with a 1 µF or greater capacitor.
005
EN 3 4 ADJ
12188- Figure 5. 5-Lead TSOT, Adjustable Output Pin Configuration
Table 6. Adjustable Output, 5-Lead TSOT Pin Function Descriptions Pin No. Mnemonic Description
1 VIN Regulator Input Supply. Bypass VIN to GND with a 1 µF or greater capacitor. 2 GND Ground. 3 EN Enable Input. Drive EN high to turn on the regulator; drive EN low to turn off the regulator. For automatic startup, connect EN to VIN. 4 ADJ Output Voltage Adjust Pin. Connect the midpoint of the voltage divider between VOUT and GND to this pin to set the output voltage. 5 VOUT Regulated Output Voltage. Bypass VOUT to GND with a 1 µF or greater capacitor. Rev. A | Page 6 of 23 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUITS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS RECOMMENDED SPECIFICATIONS: INPUT AND OUTPUT CAPACITORS ABSOLUTE MAXIMUM RATINGS THERMAL DATA THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION CAPACITOR SELECTION Output Capacitor, COUT Input Bypass Capacitor, CIN Input and Output Capacitor Properties ENABLE FEATURE UNDERVOLTAGE LOCKOUT (UVLO) CURRENT-LIMIT AND THERMAL OVERLOAD PROTECTION THERMAL CONSIDERATIONS PCB LAYOUT CONSIDERATIONS LIGHT SENSITIVITY OF WLCSPs OUTLINE DIMENSIONS ORDERING GUIDE
