Datasheet LT3065 (Analog Devices) - 2
Description45V VIN, 500mA Low Noise, Linear Regulator with Programmable Current Limit and Power Good
Pages / Page28 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION …
RevisionD
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LT3065 Series
LT3065 Series
IN Pin Voltage ...±50V Output Short-Circuit Duration .. Indefinite OUT Pin Voltage ... +40V, –50V Operating Junction Temperature Range (Notes 3, 5, 14) Input-to-Output Differential Voltage (Note 2) ..+50V, –40V E-, I-Grades ... –40°C to 125°C ADJ Pin Voltage ..±50V MP-Grade .. –55°C to 150°C SENSE Pin Voltage ..±50V H-Grade ... –40°C to 150°C SHDN Pin Voltage ...±50V Storage Temperature Range .. –65°C to 150°C PWRGD Pin Voltage ...–0.3V, 50V Lead Temperature (Soldering, 10 sec) IMAX Pin Voltage ..–0.3V, 7V MSOP Package Only ...300°C REF/BYP Pin Voltage ...1V
PIN CONFIGURATION
TOP VIEW TOP VIEW IN 1 10 OUT IN 1 12 OUT IN 2 9 OUT IN 2 11 OUT 11 SHDN 3 13 10 ADJ/SENSE* SHDN 3 GND 8 ADJ/SENSE* PWRGD 4 GND 9 GND/ADJ* PWRGD 4 7 GND/ADJ* I 5 MAX 8 REF/BYP IMAX 5 6 REF/BYP NC 6 7 NC DD PACKAGE MSE PACKAGE 10-LEAD (3mm × 3mm) PLASTIC DFN 12-LEAD PLASTIC MSOP T T JMAX = 150°C, θJA = 28°C/W, θJC = 6°C/W JMAX = 150°C, θJA = 31°C/W, θJC = 9°C/W EXPOSED PAD (PIN 13) IS GND, MUST BE SOLDERED TO PCB EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB *Pin 7: GND for LT3065, ADJ for LT3065-1.2, LT3065-1.5, LT3065-1.8, LT3065-2.5, *Pin 9: GND for LT3065, ADJ for LT3065-1.2, LT3065-1.5, LT3065-1.8, LT3065-2.5, LT3065-3.3, LT3065-5 LT3065-3.3, LT3065-5 *Pin 8: ADJ for LT3065, SENSE for LT3065-1.2, LT3065-1.5, LT3065-1.8, LT3065-2.5, *Pin 10: ADJ for LT3065, SENSE for LT3065-1.2, LT3065-1.5, LT3065-1.8, LT3065-2.5, LT3065-3.3, LT3065-5 LT3065-3.3, LT3065-5
LT3065EDD#PBF LT3065EDD#TRPBF LGKS 10-Lead (3mm x 3mm) Plastic DFN –40°C to 125°C LT3065IDD#PBF LT3065IDD#TRPBF LGKS 10-Lead (3mm x 3mm) Plastic DFN –40°C to 125°C LT3065HDD#PBF LT3065HDD#TRPBF LGKS 10-Lead (3mm x 3mm) Plastic DFN –40°C to 150°C LT3065MPDD#PBF LT3065MPDD#TRPBF LGKS 10-Lead (3mm x 3mm) Plastic DFN –55°c to 150°C LT3065EDD-1.2#PBF LT3065EDD-1.2#TRPBF LGQV 10-Lead (3mm x 3mm) Plastic DFN –40°C to 125°C LT3065IDD-1.2#PBF LT3065IDD-1.2#TRPBF LGQV 10-Lead (3mm x 3mm) Plastic DFN –40°C to 125°C LT3065HDD-1.2#PBF LT3065HDD-1.2#TRPBF LGQV 10-Lead (3mm x 3mm) Plastic DFN –40°C to 150°C LT3065MPDD-1.2#PBF LT3065MPDD-1.2#TRPBF LGQV 10-Lead (3mm x 3mm) Plastic DFN –55°C to 150°C LT3065EDD-1.5#PBF LT3065EDD-1.5#TRPBF LGQW 10-Lead (3mm x 3mm) Plastic DFN –40°C to 125°C LT3065IDD-1.5#PBF LT3065IDD-1.5#TRPBF LGQW 10-Lead (3mm x 3mm) Plastic DFN –40°C to 125°C LT3065HDD-1.5#PBF LT3065HDD-1.5#TRPBF LGQW 10-Lead (3mm x 3mm) Plastic DFN –40°C to 150°C LT3065MPDD-1.5#PBF LT3065MPDD-1.5#TRPBF LGQW 10-Lead (3mm x 3mm) Plastic DFN –55°C to 150°C LT3065EDD-1.8#PBF LT3065EDD-1.8#TRPBF LGQX 10-Lead (3mm x 3mm) Plastic DFN –40°C to 125°C LT3065IDD-1.8#PBF LT3065IDD-1.8#TRPBF LGQX 10-Lead (3mm x 3mm) Plastic DFN –40°C to 125°C LT3065HDD-1.8#PBF LT3065HDD-1.8#TRPBF LGQX 10-Lead (3mm x 3mm) Plastic DFN –40°C to 150°C LT3065MPDD-1.8#PBF LT3065MPDD-1.8#TRPBF LGQX 10-Lead (3mm x 3mm) Plastic DFN –55°C to 150°C LT3065EDD-2.5#PBF LT3065EDD-2.5#TRPBF LGQY 10-Lead (3mm x 3mm) Plastic DFN –40°C to 125°C Rev.D 2 For more information www.analog.com Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Block Diagram Applications Information Typical Applications Package Description Typical Application Related Parts
