Datasheet ADP160, ADP161, ADP162, ADP163 (Analog Devices) - 6
DescriptionUltralow Quiescent Current, 150 mA, CMOS Linear Regulators
Pages / Page24 / 6 — ADP160/ADP161/ADP162/ADP163. Data Sheet. PIN CONFIGURATIONS AND FUNCTION …
RevisionH
File Format / SizePDF / 605 Kb
ADP160/ADP161/ADP162/ADP163. Data Sheet. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. VIN 1. ADP160/. VOUT. ADP162. GND 2. TOP VIEW
ADP160/ADP161/ADP162/ADP163 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS VIN 1 ADP160/ VOUT ADP162 GND 2 TOP VIEW
ADP160/ADP161/ADP162/ADP163 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS VIN 1 ADP160/ 5 VOUT ADP162 GND 2 TOP VIEW (Not to Scale) EN 3 4 NC
04 0 8-
NC = NO CONNECT
62 08 Figure 4. 5-Lead TSOT, Fixed Output Pin Configuration, ADP160/ADP162
Table 5. 5-Lead TSOT Pin Function Descriptions, ADP160/ ADP162 Pin No. Mnemonic Description
1 VIN Regulator Input Supply. Bypass VIN to GND with a 1 μF or greater capacitor. 2 GND Ground. 3 EN Enable Input. Drive EN high to turn on the regulator; drive EN low to turn off the regulator. For automatic startup, connect EN to VIN. 4 NC No Connect. This pin is not connected internally. Connect this pin to GND or leave open. 5 VOUT Regulated Output Voltage. Bypass VOUT to GND with a 1 μF or greater capacitor.
VIN 1 ADP161/ 5 VOUT ADP163 GND 2 TOP VIEW (Not to Scale)
5 00
EN 3 4 ADJ
8- 62 08 Figure 5. 5-Lead TSOT, Adjustable Output Pin Configuration, ADP161/ADP163
Table 6. 5-Lead TSOT Pin Function Descriptions, ADP161/ ADP163 Pin No. Mnemonic Description
1 VIN Regulator Input Supply. Bypass VIN to GND with a 1 μF or greater capacitor. 2 GND Ground. 3 EN Enable Input. Drive EN high to turn on the regulator; drive EN low to turn off the regulator. For automatic startup, connect EN to VIN. 4 ADJ Output Voltage Adjust Pin. Connect the midpoint of the voltage divider between VOUT and GND to this pin to set the output voltage. 5 VOUT Regulated Output Voltage. Bypass VOUT to GND with a 1 μF or greater capacitor. Rev. H | Page 6 of 24 Document Outline Features Applications Typical Application Circuits General Description Table of Contents Revision History Specifications Input and Output Capacitor, Recommended Specifications Absolute Maximum Ratings Thermal Data Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Capacitor Selection Output Capacitor Input Bypass Capacitor Input and Output Capacitor Properties Enable Feature Current Limit and Thermal Overload Protection Thermal Considerations PCB Layout Considerations Light Sensitivity of WLCSPs Outline Dimensions Ordering Guide
