Datasheet HMC860LP3E (Analog Devices) - 10
DescriptionQuad Low Noise High PSRR Linear Voltage Regulator
Pages / Page10 / 10 — HMC860LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. …
File Format / SizePDF / 699 Kb
HMC860LP3E. QUAD LOW NOISE HIGH PSRR. LINEAR VOLTAGE REGULATOR. Evaluation PCB. List of Materials for Evaluation PCB 124352 [1]
HMC860LP3E QUAD LOW NOISE HIGH PSRR LINEAR VOLTAGE REGULATOR Evaluation PCB List of Materials for Evaluation PCB 124352 [1]
HMC860LP3E
v01.0811
9 T M G - S IN N IO
IT Item Description Item Description D J7 - J20 2 Pos Vertical TIN PCB [2] 124072 Evaluation PCB N C7 4.7 µF Capacitor, 0805 Pkg. [1] Reference this number when ordering complete evaluation PCB O C10, C11, C13, C14, [2] Circuit Board Material: Rogers 4350 or FR4 100 nF Capacitor, 0402 Pkg. C19, C21, C23, C25 C12 1.0 µF Capacitor, 0603 Pkg. R C A sufficient number of via holes should be used to E C15 - C18 10 µF Capacitor, 0805 Pkg. connect the top and bottom ground planes. The C20, C22, C24, C26 1000 pF Capacitor, 0402 Pkg. evaluation circuit board shown is available from W R13, R16, R18, R21, Hittite upon request. O 1 Ohm Resistor, 0402 Pkg. R29 P R23, R25 0.2 Ohm Resistor, 0402 Pkg. R24, R26 - R28 0 Ohm Resistor, 0402 Pkg. TP1 - TP3 Test Point PC Compact U1 HMC860LP3E Quad Regulator Inf F or o m ra tip o r n ifc ur e n ,is hd e e d lbiv y e A r n y al oa g n D d evi tco e s p is la beclie ev eo d rtd o ebre sa: H ccur iattti e taen M d re ilicarbloew . H a o ve wev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 978-250-3343 tel • 978-250-3373 fax • O rights of third parties that may result from its use. Specifications subject to change without notice. No rd P e h r o nO e n : 7 -li 81 n - e 32 a 9- t 4 w 70 ww. 0 • Ohi rd tt e ite r on.lc inom license is granted by implication or otherwise under any patent or patent rights of Analog Devices. e at www.analog.com
9 - 10
Application Trademarks and registered trademarks are the property of their respective owners.Support: apps@ A h ppitlitcitae ti .oco n Sm upport: Phone: 1-800-ANALOG-D
