Data Brief PAM8823 (Diodes)
Manufacturer | Diodes |
Description | 25WX2 Stereo / 50WX1 Mono Digital Audio Amplifier With EQ & DRC |
Pages / Page | 1 / 1 — PAM8823 Data Brief. 25Wx2 STEREO/50Wx1 MONO DIGITAL AUDIO AMPLIFIER WITH … |
File Format / Size | PDF / 190 Kb |
PAM8823 Data Brief. 25Wx2 STEREO/50Wx1 MONO DIGITAL AUDIO AMPLIFIER WITH EQ & DRC. Description. Features. Applications
PAM8823 Data Brief 25Wx2 STEREO/50Wx1 MONO DIGITAL AUDIO AMPLIFIER WITH EQ & DRC Description Features
The PAM8823 is a high efficiency, Stereo 25W / Mono 50W Class D Wide 4.5V to 26V for Loudspeaker Drive, 3.3V for Digital Circuit digital audio amplifier with I2S input to drive stereo bridge-tied Loudspeaker Output Power@12V for Stereo speakers. The PAM8823 is capable of driving Stereo 25W (BTL) each 7W 2CH into 8Ω <1% THD+N to a pair of 8Ω load speaker or Mono 50W (PBTL) to a 4Ω load 10W 2CH into 4Ω <1% THD+N speaker operating at 24V supply without external heat-sink or fan Loudspeaker Output Power@18V for Stereo requirement at playing music. 15W 2CH into 8Ω <1% THD+N Loudspeaker Output power@24V for stereo With embedded Audio DSP to support advanced features as volume 25W 2CH into 8Ω <1% THD+N control, 30 EQ bands, audio mixing, 3D surround sound and Dynamic Loudspeaker PSNR 108dB, DR 108dB @24V Range Control (DRC), the PAM8823 is capable to provide a high- 16/18/20/24-bits Input with I2S, Left-Alignment & Right-Alignment quality audio output with flexible digital audio processing capability. Data Format Support These features are fully programmable via a simple I2C control Multiple Sampling Frequencies (fS), Including interface, with robust protection circuits to protect PAM8823 from 8/32/44.1/48/64/88.2/96/128/176.4/192kHz damage by accidental erroneous operating condition. These Support Stereo 2 Channels or Mono by PBTL Configuration protection features include Short-Circuit (SCP), Over-Temperature Digital Audio Processor Features Include (OTP), Over-Voltage (OVP) & Under-Voltage-Lockout (UVLO) 30 Bands Configurable Parametric Speaker EQ protections. Volume Control (+24dB to -103dB, 0.125dB/Step) Dynamic Range Control with Power Clipping The PAM8823 is also pop-free designed during instantaneous power Three-Band Configuration plus Post Dynamic Range Control on/off or mute/shut down switching by anti-pop circuit built-in. The Programmed 3D Surround Sound & Channel Mixing PAM8823 is a slave-only device receiving all clocks from external Noise Reduction Control & Bass/Treble Tone Control sources or internal PLL built-in. It is capable to support sampling rate Level Meter and Power Meter Support from 8kHz to 192kHz. With oversampling technology combined with I2S SDATAO Outputs Selectable for Audio Monitoring, Sub- an advanced noise shaper design, the PAM8823 provides a flat noise Channel or Echo Cancellation (Only by TSSOP-24EP (Type floor and excellent dynamic range from 20Hz to 20kHz. A1)) Short Circuit / Over-Temperature / Over-Voltage Protection The PAM8823 is packaged in 48-pin, L-QFP7070-48EP (Type A1) or Serial Control Interface with Selectable Device Address TSSOP-24EP (Type A1). LV Under-Voltage Shutdown & HV Under-Voltage Detection Flexible Power Saving Mode with Internal PLL Design
Applications
L-QFP7070-48EP (Type A1) & TSSOP-24EP (Type A1) (Upon Request) Packages Flat Monitor & LCD TVs Moisture Sensitivity: Level 3 JEDEC-STD-22 Multi-Media Speaker System, Wireless Speakers Terminals: Finish – Matte Tin Plated Leads, Solderable per Boom Box, Sound Bar, DVD Players, Game Machines JEDEC-STD-22, Method B102 Condition E Music Instruments & Consumer Electronics Application Weight: L-QFP7070-48EP (Type A1): 0.178 grams (Approximate) TSSOP-24EP (Type A1): 0.093 grams (Approximate)
Lead-Free Finish; RoHS Compliant (Notes 1 & 2) Halogen and Antimony Free. “Green” Device (Note 3) For automotive applications requiring specific change control (i.e. parts qualified to AEC-Q100/101/200, PPAP capable, and manufactured in IATF 16949 certified facilities), please contact us or your local Diodes representative. https://www.diodes.com/quality/product-definitions/
Notes: 1. EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. All applicable RoHS exemptions applied. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. PAM8823 Data Brief 1 of 1 June 2020 Document number: DS41932 Rev. 1 - 1
www.diodes.com
© Diodes Incorporated
