Datasheet EFM8LB1 (Silicon Labs) - 5
Manufacturer | Silicon Labs |
Description | EFM8 Laser Bee Family |
Pages / Page | 77 / 5 — Ordering Part Number. Flash Memory (kB). RAM (Bytes). Digital Port I/Os … |
File Format / Size | PDF / 1.2 Mb |
Ordering Part Number. Flash Memory (kB). RAM (Bytes). Digital Port I/Os (Total). ADC0 Channels. Voltage DACs. Comparator 0 Inputs
link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 16 EFM8LB1 Data Sheet Ordering Information
Ordering Part Number Flash Memory (kB) RAM (Bytes) Digital Port I/Os (Total) ADC0 Channels Voltage DACs Comparator 0 Inputs Comparator 1 Inputs Bootloader Type Bootloader Pins Pb-free (RoHS Compliant) Package
EFM8LB11F16ES1-C-QFN24 16 1280 20 12 21 6 6 SMBus P0.2 / P0.42 Yes QFN24 EFM8LB10F16E-C-QFN32 16 1280 29 20 0 10 9 UART P0.4 / P0.52 Yes QFN32 EFM8LB10F16E-C-QFP32 16 1280 28 20 0 10 9 UART P0.4 / P0.52 Yes QFP32 EFM8LB10F16E-C-QFN24 16 1280 20 12 0 6 6 UART P0.4 / P0.52 Yes QFN24 EFM8LB10F16E-C-QSOP24 16 1280 21 13 0 6 7 UART P0.4 / P0.52 Yes QSOP24 EFM8LB10F16ES0-C-QFN32 16 1280 29 20 0 10 9 SMBus P0.2 / P0.32 Yes QFN32 EFM8LB10F16ES0-C-QFN24 16 1280 20 12 0 6 6 SMBus P0.2 / P0.32 Yes QFN24 EFM8LB10F16ES1-C-QFN32 16 1280 29 20 0 10 9 SMBus P0.2 / P0.42 Yes QFN32 EFM8LB10F16ES1-C-QFN24 16 1280 20 12 0 6 6 SMBus P0.2 / P0.42 Yes QFN24
Note:
1. DAC0 and DAC1 are enabled on devices with 2 DACs available. 2. See 3.10 Bootloader for more information on the bootloader types and pin usage.
silabs.com
| Building a more connected world. Rev. 1.3 | 5 Document Outline 1. Feature List 2. Ordering Information 3. System Overview 3.1 Introduction 3.2 Power 3.3 I/O 3.4 Clocking 3.5 Counters/Timers and PWM 3.6 Communications and Other Digital Peripherals 3.7 Analog 3.8 Reset Sources 3.9 Debugging 3.10 Bootloader 4. Electrical Specifications 4.1 Electrical Characteristics 4.1.1 Recommended Operating Conditions 4.1.2 Power Consumption 4.1.3 Reset and Supply Monitor 4.1.4 Flash Memory 4.1.5 Power Management Timing 4.1.6 Internal Oscillators 4.1.7 External Clock Input 4.1.8 External Oscillator 4.1.9 ADC 4.1.10 Voltage Reference 4.1.11 Temperature Sensor 4.1.12 1.8 V Internal LDO Voltage Regulator 4.1.13 DACs 4.1.14 Comparators 4.1.15 Configurable Logic 4.1.16 Port I/O 4.1.17 SMBus 4.2 Thermal Conditions 4.3 Absolute Maximum Ratings 5. Typical Connection Diagrams 5.1 Power 5.2 Debug 5.3 Other Connections 6. Pin Definitions 6.1 EFM8LB1x-QFN32 Pin Definitions 6.2 EFM8LB1x-QFP32 Pin Definitions 6.3 EFM8LB1x-QFN24 Pin Definitions 6.4 EFM8LB1x-QSOP24 Pin Definitions 7. QFN32 Package Specifications 7.1 Package Dimensions 7.2 PCB Land Pattern 7.3 Package Marking 8. QFP32 Package Specifications 8.1 Package Dimensions 8.2 PCB Land Pattern 8.3 Package Marking 9. QFN24 Package Specifications 9.1 Package Dimensions 9.2 PCB Land Pattern 9.3 Package Marking 10. QSOP24 Package Specifications 10.1 Package Dimensions 10.2 PCB Land Pattern 10.3 Package Marking 11. Revision History
