Datasheet SiRA99DP (Vishay) - 2
ManufacturerVishay
DescriptionP-Channel 30 V (D-S) MOSFET
Pages / Page9 / 2 — SiRA99DP. SPECIFICATIONS. PARAMETER. SYMBOL TEST. CONDITIONS MIN. TYP. …
File Format / SizePDF / 251 Kb
SiRA99DP. SPECIFICATIONS. PARAMETER. SYMBOL TEST. CONDITIONS MIN. TYP. MAX. UNIT. Static. Dynamic b
SiRA99DP SPECIFICATIONS PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNIT Static Dynamic b
SiRA99DP
SPECIFICATIONS
(TJ = 25 °C, unless otherwise noted)
PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Static
Drain-source breakdown voltage VDS VGS = 0 V, ID = -250 μA -30 - - V VDS temperature coefficient VDS/TJ ID = -10 mA - -14 - mV/°C VGS(th) temperature coefficient VGS(th)/TJ ID = -250 μA - 6 - Gate-source threshold voltage VGS(th) VDS = VGS, ID = -250 μA -1 - -2.5 V Gate-source leakage IGSS VDS = 0 V, VGS = +16 / -20 V - - 100 nA VDS = -30 V, VGS = 0 V - - -1 Zero gate voltage drain current IDSS μA VDS = -30 V, VGS = 0 V, TJ = 70 °C - - -15 On-state drain current a ID(on) VDS  -10 V, VGS = -10 V -40 - - A VGS = -10 V, ID = -20 A - 0.00130 0.00170 Drain-source on-state resistance a R DS(on) VGS = -4.5 V, ID = -15 A - 0.00220 0.00265 Forward transconductance a gfs VDS = -15 V, ID = -20 A - 114 - S
Dynamic b
Input capacitance Ciss - 10 995 - Output capacitance Coss VDS = -15 V, VGS = 0 V, f = 1 MHz - 5000 - pF Reverse transfer capacitance Crss - 510 - VDS = -15 V, VGS = -10 V, ID = -20 A - 172.5 260 Total gate charge Qg - 84 126 nC Gate-source charge Qgs VDS = -15 V, VGS = -4.5 V, ID = -20 A - 35.6 - Gate-drain charge Qgd - 27.5 - Gate resistance Rg f = 1 MHz 0.5 1.3 2.2 Turn-on delay time td(on) - 23 46 Rise time tr V - 19 38 DD = -15 V, RL = 0.75 , ID  -20 A, V Turn-off delay time t GEN = -10 V, Rg = 1 d(off) - 64 128 Fall time tf - 16 32 ns Turn-on delay time td(on) - 69 138 Rise time tr V - 183 366 DD = -15 V, RL = 0.75 , ID  -20 A, V Turn-off delay time t GEN = -4.5 V, Rg = 1 d(off) - 51 102 Fall time tf - 57 114
Drain-Source Body Diode Characteristics
Continuous source-drain diode current IS TC = 25 °C - - -94.5 A Pulse diode forward current ISM - - -400 Body diode voltage VSD IS = -5 A, VGS = 0 V - -0.71 -1.1 V Body diode reverse recovery time trr - 75 150 ns Body diode reverse recovery charge Qrr I - 125 250 nC F = -20 A, di/dt = 100 A/μs, T Reverse recovery fall time t J = 25 °C a - 31 - ns Reverse recovery rise time tb - 39 -
Notes
a. Pulse test; pulse width  300 μs, duty cycle  2 % b. Guaranteed by design, not subject to production testing Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. S19-0115-Rev. A, 04-Feb-2019
2
Document Number: 71023 For technical questions, contact: pmostechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
