Datasheet SKY16603-632LF (Skyworks) - 3
ManufacturerSkyworks
DescriptionHigh-Linearity Dual PIN Diode Limiter
Pages / Page10 / 3 — DATA SHEET ● SKY16603-632LF: High-Linearity Dual PIN Diode Limiter 0.6 to …
DATA SHEET ● SKY16603-632LF: High-Linearity Dual PIN Diode Limiter 0.6 to 6.0 GHz
DATA SHEET ● SKY16603-632LF: High-Linearity Dual PIN Diode Limiter 0.6 to 6.0 GHz Electrical and Mechanical Specifications
The absolute maximum ratings of the SKY16603-632LF are Figure 6 shows the power derating curve for the limiter. The provided in Table 2. Electrical specifications are provided in temperature is referenced to the bottom of the DFN package. Table 3. The SKY16603-632LF schematic is shown in Figure 3, and typical performance characteristics are illustrated in Figures 4 and 5.
Table 2. SKY16603-632LF Absolute Maximum Ratings1 Parameter Symbol Minimum Maximum Unit
CW power dissipation at TCASE = 120°C PDIS 1 W Storage temperature TSTG -65 150 °C Operating temperature TOP -40 105 °C Electrostatic discharge: ESD Charged-Device Model (CDM), Class 4 1000 V Human Body Model (HBM), Class 1B 250 V Machine Model (MM), Class A 150 V 1 Exposure to maximum rating conditions for extended periods may reduce device reliability. There is no damage to device with only one parameter set at the limit and all other parameters set at or below their nominal value. Exceeding any of the limits listed here may result in permanent damage to the device.
ESD HANDLING
: Although this device is designed to be as robust as possible, electrostatic discharge (ESD) can damage this device. This device must be protected at all times from ESD when handling or transporting. Static charges may easily produce potentials of several kilovolts on the human body or equipment, which can discharge without detection. Industry-standard ESD handling precautions should be used at all times.
Table 3. SKY16603-632LF Electrical Specifications (TOP = 25
C, ZO = 50 ohms, as Measured in Skyworks Evaluation Board Optimized for Operation at 0.6 to 6.0 GHz, Unless Otherwise Noted) Parameter Symbol Condition Frequency Min Typ Max Units
Reverse voltage VR 20 V Forward current IF 50 mA Insertion loss IL PIN = 0 dBm 2.6 GHz 0.3 0.5 dB Return loss RL PIN = 0 dBm 2.6 GHz 22 dB Threshold level TL P1dB 2.6 GHz 8 dBm Maximum saturated CW input power1 PIN_MAX Tc = 120 °C 2.6 GHz 35 dBm Flat leakage power2 FL PIN = +15 dBm 2.6 GHz 5.5 9 dBm Two CW tones, PIN = -5 dBm per Input third order intercept point IIP3 2.6 GHz 25 29 dBm tone, spacing = 10 MHz Recovery time3 tR 2.6 GHz 1 ns Thermal resistance θJC Junction-to-case (Tc = 120 °C) 52 °C/W 1 Saturated CW input power is defined as the point where the diode series resistance does not change with the rectified current. As the input power increases past this point, output power will increase until the diode reaches its maximum power limit. 2 Flat leakage power is defined as the power level after the limiter has fully turned on and the output pulse reaches a constant level. 3 Recovery time represents the transition time from the high-loss to low-loss state following the removal of high-power input. RF pulse modulation: 1 us pulse width and 0.1% duty factor. Skyworks Solutions, Inc. • Phone [781] 376-3000 • Fax [781] 376-3100 • sales@skyworksinc.com • www.skyworksinc.com 205442F • Skyworks Proprietary Information • Products and Product Information are Subject to Change Without Notice • June 26, 2020 3
