15 /7 — Data Sheet. ADL5391. TYPICAL PERFORMANCE CHARACTERISTICS. 3.0. 200. Y = …
Revision
A
PDF / 524 Kb
Data Sheet. ADL5391. TYPICAL PERFORMANCE CHARACTERISTICS. 3.0. 200. Y = –2. 2.5. Y = –1. Y = 0. 150. 2.0. Y = +1. 1.5. Y = +2. 100. 1.0. 0.5. rees). Deg. N (
Data SheetADL5391TYPICAL PERFORMANCE CHARACTERISTICS GADJ = open. 3.014200Y = –22.5Y = –112Y = 0150102.0Y = +181.5Y = +210061.04)500.5rees)DCB)2d(VDegF00–0N ((FAIEDI–0.5–2GW–50–4HAS–1.0P–6–1.5–100–8–2.0–10–150–2.5–12–3.0–14–2005–2.5–2.0–1.5–1.0–0.500.51.01.52.02.5 007 10019529038548057567076586095510501150124013401430153016201720181019102000 010 XDIFF (VDC) 06059- FREQUENCY (MHz) 06059- Figure 3. Full Range DC Cross Plots Figure 6. Gain and Phase vs. Frequency of X Swept and Y = 1 V, Z = 0 V, PIN = 0 dBm 0.2042000.1531500.102100)0.05150rees)DCB) d(VDegF00–0N ((FAIEDIGW –0.05–1–50HAS P–0.10Y = –2–2–100Y = –1 Y = 0–0.15–3–150Y = +1 Y = +2–0.20–4–2001–0.20–0.15–0.10–0.0500.050.100.150.20 008 110220330440550660700880990110012001300 011 XDIFF (VDC) 06059- FREQUENCY (MHz) 06059- Figure 4. Magnified DC Cross Plots Figure 7. Gain and Phase vs. Frequency of Z Inputs, X = 0 V, Y = 0 V, PIN = 0 dBm 2.52.0X ± INPUT = 1.0V p-p, @ 200MHz Y ± INPUT = 1.0V DC DIFFERENTIAL1.52.01.00.51.5V)(V)UT(V/P0INUTAOG1.0W–0.5–1.00.5–1.50–2.0–1.0–0.500.51.01.52.024.525.526.527.528.529.530.531.532.533.5 013 009 GADJ (VTIME (ns)DC) 06059- 06059- Figure 5. Gain vs. GADJ (X = Y = 1) Figure 8. Large Signal Pulse Response Rev. A | Page 7 of 15 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Basic Theory Calibration Basic Connections Multiplier Connections Matching the Input/Output Wideband Voltage-Controlled Amplifier/Amplitude Modulator Squaring and Frequency Doubling Use as a Detector Evaluation Board Outline Dimensions Ordering Guide
