Enhanced ProductAD633-EPSPECIFICATIONS TA = 25°C, VS = ±15 V, RL ≥ 2 kΩ. Table 1. ParameterConditionsMinTypMaxUnit TRANSFER FUNCTION (X1− X2)(Y1−Y2) W = + Z 10 V MULTIPLIER PERFORMANCE Total Error −10 V ≤ X, Y ≤ +10 V ±1 ±2 % full scale TMIN to TMAX ±3 % full scale Scale Voltage Error SF = 10.00 V nominal ±0.25% % full scale Supply Rejection VS = ±14 V to ±16 V ±0.01 % full scale Nonlinearity, X X = ±10 V, Y = +10 V ±0.4 ±1 % full scale Nonlinearity, Y Y = ±10 V, X = +10 V ±0.1 ±0.4 % full scale X Feedthrough Y nulled, X = ±10 V ±0.3 ±1 % full scale Y Feedthrough X nulled, Y = ±10 V ±0.1 ±0.4 % full scale Output Offset Voltage1 ±5 ±50 mV DYNAMICS Small Signal Bandwidth VO = 0.1 V rms 1 MHz Slew Rate VO = 20 V p-p 20 V/µs Settling Time to 1% ΔVO = 20 V 2 µs OUTPUT NOISE Spectral Density 0.8 µV/√Hz Wideband Noise f = 10 Hz to 5 MHz 1 mV rms f = 10 Hz to 10 kHz 90 µV rms OUTPUT Output Voltage Swing ±11 V Short Circuit Current RL = 0 Ω 30 40 mA INPUT AMPLIFIERS Signal Voltage Range Differential ±10 V Common mode ±10 V Offset Voltage (X, Y) ±5 ±30 mV CMRR (X, Y) VCM = ±10 V, f = 50 Hz 60 80 dB Bias Current (X, Y, Z) 0.8 2.0 µA Differential Resistance 10 MΩ POWER SUPPLY Supply Voltage Rated Performance ±15 V Operating Range ±8 ±18 V Supply Current Quiescent 4 6 mA 1 Allow approximately 0.5 ms for settling following power on. Rev. B | Page 3 of 7 Document Outline Features Enhanced Product Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications Absolute Maximum Ratings Thermal Resistance Power Derating Curve ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Outline Dimensions Ordering Guide
