Datasheet AD539 (Analog Devices) - 5
DescriptionWideband Dual-Channel Linear Multiplier/Divider
Pages / Page20 / 5 — AD539. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. P M. 20 19. VY1 4. …
RevisionB
File Format / SizePDF / 371 Kb
AD539. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. P M. 20 19. VY1 4. 18 CHAN1 OUTPUT. +V 5. 17 BASE COMMON. NC 6. 16 NC. TOP VIEW. –VS 7
AD539 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS P M 20 19 VY1 4 18 CHAN1 OUTPUT +V 5 17 BASE COMMON NC 6 16 NC TOP VIEW –VS 7
AD539 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS P M CO X HF V NC W1 Z1 3 2 1 20 19 VY1 4 18 CHAN1 OUTPUT +V 5 S 17 BASE COMMON AD539 NC 6 16 NC TOP VIEW –VS 7 (Not to Scale) 15 BASE COMMON VY2 8 14 CHAN2 OUTPUT 9 10 11 12 13 N N Z2 O NC W2 M MMO M O C CO NOTES T UT 1. NC = NO CONNECT. DO NOT PU P CONNECT TO THIS PIN.
-002
T IN U
679
O
09 Figure 2. 20-Lead LLC Pin Configuration (E-20-1)
Table 2. 20-Lead LLC Pin Function Descriptions Pin No. Mnemonic Description
1 NC No Connect. Do not connect to this pin. 2 VX Control Channel Input. 3 HF COMP High Frequency Compensation. 4 VY1 Channel 1 Input. 5 +VS Positive Supply Rail. 6 NC No Connect. Do not connect to this pin. 7 –VS Negative Supply Rail. 8 VY2 Channel 2 Input. 9 INPUT COMMON Internal Common Connection for the Input Amplifier Circuitry. 10 OUTPUT COMMON Internal Common Connection for the Output Amplifier Circuitry. 11 NC No Connect. 12 W2 6 kΩ Feedback Resistor for Channel 2. 13 Z2 6 kΩ Feedback Resistor for Channel 2. 14 CHAN2 OUTPUT Channel 2 Product of VX and VY2. 15 BASE COMMON Increases Negative Output Compliance. 16 NC No Connect. Do not connect to this pin. 17 BASE COMMON Increases Negative Output Compliance. 18 CHAN1 OUTPUT Channel 1 Product of VX and VY1. 19 Z1 6 kΩ Feedback Resistor for Channel 1. 20 W1 6 kΩ Feedback Resistor for Channel 1. Rev. B | Page 5 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT DESCRIPTION GENERAL RECOMMENDATIONS TRANSFER FUNCTION DUAL SIGNAL CHANNELS COMMON CONTROL CHANNEL FLEXIBLE SCALING APPLICATIONS INFORMATION BASIC MULTIPLIER CONNECTIONS Signal Channel AC and Transient Response Minimal Wideband Configurations Differential Configurations A 50 MHZ VOLTAGE-CONTROLLED AMPLIFIER BASIC DIVIDER CONNECTIONS Standard Scaling OUTLINE DIMENSIONS ORDERING GUIDE
