Datasheet AD539 (Analog Devices) - 7
DescriptionWideband Dual-Channel Linear Multiplier/Divider
Pages / Page20 / 7 — AD539. TYPICAL PERFORMANCE CHARACTERISTICS. 50ns. 100. B) d (. AD539J, S. …
File Format / SizePDF / 371 Kb
AD539. TYPICAL PERFORMANCE CHARACTERISTICS. 50ns. 100. B) d (. AD539J, S. SPECS. RRO. 0 AD539K. E S. S O L N/ –1. AI G. 0.01. 0.1. VX = +3V
AD539 TYPICAL PERFORMANCE CHARACTERISTICS 50ns 100 B) d ( AD539J, S SPECS RRO 0 AD539K E S S O L N/ –1 AI G 0.01 0.1 VX = +3V
VY = VY1 − VY2, VX = VX1 – VX2, unless otherwise noted.
3 1V 50ns 2 100 90 B) d ( 1 AD539J, S RS SPECS RRO 0 AD539K E S SPECS S O L N/ –1 AI G 10 –2 0% 2V –3
007 4 79-
0.01 0.1 1 10
-009 96
VX = +3V
0
CONTROL VOLTAGE (V
67
X)
09 Figure 4. Maximum AC Gain Error Boundaries Figure 7. Multiplier Pulse Response Using LH0032 Op Amp, VX = 3 V
0.20 f = 10kHz 1V 50ns ) % 100 N ( 0.15 90 IO RT O T S C DI 0.10 NI O VY = 1.5V rms HARM 0.05 AL T O 10 T VY = 0.5V rms 0% 100mV 0
008 79-
0 1 2
05 0
3
9- 96
VX = +0.1V
0
CONTROL VOLTAGE (V)
967 0 Figure 5. Total Harmonic Distortion vs. Control Voltage Figure 8. Multiplier Pulse Response Using LH0032 Op Amp, VX = 0.1 V
20 0 VX = 3.162V V 10 X = 3.162V ) ) –10 B B (d VX = 1.00V 0 VX = 1.00V SE SE (d –20 N V N X = 0.316V O –10 VX = 0.316V ESPO ESP –30 VX = 0.1V Y R –20 Y R C C V N N X = 0.1V E V –40 E U X = 0.032V –30 U EQ EQ V R V R X = 0.032V –50 F X = 0.01V –40 F H H IG IG V H H X = 0.01V –50 –60 FEEDTHROUGH VX = –0.01V –60 –70
9
100k 1M 10M 100M
006
100k 1M 10M 100M
00
FREQUENCY (Hz)
679-
FREQUENCY (Hz)
679- 09 09 Figure 6. Multiplier High Frequency Response Using LH0032 Op Amps Figure 9. High Frequency Response in Minimal Configuration Rev. B | Page 7 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT DESCRIPTION GENERAL RECOMMENDATIONS TRANSFER FUNCTION DUAL SIGNAL CHANNELS COMMON CONTROL CHANNEL FLEXIBLE SCALING APPLICATIONS INFORMATION BASIC MULTIPLIER CONNECTIONS Signal Channel AC and Transient Response Minimal Wideband Configurations Differential Configurations A 50 MHZ VOLTAGE-CONTROLLED AMPLIFIER BASIC DIVIDER CONNECTIONS Standard Scaling OUTLINE DIMENSIONS ORDERING GUIDE
