Datasheet 1N5230 - 1N5267 (Vishay)
ManufacturerVishay
DescriptionSmall Signal Zener Diodes
Pages / Page6 / 1 — 1N5221 to 1N5267. Small Signal Zener Diodes. FEATURES. DESIGN SUPPORT …
Revision2.2
File Format / SizePDF / 105 Kb
1N5221 to 1N5267. Small Signal Zener Diodes. FEATURES. DESIGN SUPPORT TOOLS AVAILABLE. D 3. 3 D. APPLICATIONS
Datasheet 1N5230 - 1N5267 Vishay, Revision: 2.2
1N5221
1N5222
1N5223
1N5224
1N5225
1N5226
1N5227
1N5228
1N5229
1N5230
1N5231
1N5232
1N5233
1N5234
1N5235
1N5236
1N5237
1N5238
1N5239
1N5240
1N5241
1N5242
1N5243
1N5244
1N5245
1N5246
1N5247
1N5248
1N5249
1N5250
1N5251
1N5252
1N5253
1N5254
1N5255
1N5256
1N5257
1N5258
1N5259
1N5260
1N5261
1N5262
1N5263
1N5264
1N5265
1N5266
1N5267
1N5221 to 1N5267
Small Signal Zener Diodes FEATURES
• Silicon planar power Zener diodes • Standard Zener voltage tolerance is ± 5 % with a “B” suffix in the ordering code (e.g.: 1N5221B), suffix “C” is ± 2 % tolerance • These diodes are also available in MiniMELF case with the type designation TZM5221 to TZM5267, SOT-23 case with the type designations MMBZ5225 to MMBZ5267 and SOD-123 case with the types designations MMSZ5225 to MMSZ5267
• AEC-Q101 qualified
D 3
• Material categorization: for definitions of compliance
3 D
3D Models please see www.vishay.com/doc?99912
APPLICATIONS PRIMARY CHARACTERISTICS
• Voltage stabilization
PARAMETER VALUE UNIT
VZ range nom. 2.4 to 75 V Test current IZT 1.7 to 20 mA VZ specification Thermal equilibrium Circuit configuration Single
ORDERING INFORMATION DEVICE NAME ORDERING CODE TAPED UNITS PER REEL MINIMUM ORDER QUANTITY
1N5221B to 1N5267B 1N5221B to 1N5267B-series-TR 10 000 per 13" reel 1N5221C to 1N5267C 1N5221C to 1N5267C-series-TR 30 000/box 1N5221B to 1N5267B 1N5221B to 1N5267B-series-TAP 10 000 per ammopack (52 mm tape) 1N5221C to 1N5267C 1N5221C to 1N5267C-series-TAP
PACKAGE MOLDING COMPOUND MOISTURE SENSITIVITY PACKAGE NAME WEIGHT SOLDERING CONDITIONS FLAMMABILITY RATING LEVEL
MSL level 1 DO-35 (DO-204AH) 125 mg UL 94 V-0 Peak temperature max. 260 °C (according J-STD-020)
ABSOLUTE MAXIMUM RATINGS
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL VALUE UNIT
Power dissipation TL  25 °C Ptot 500 mW Zener current IZ Ptot/VZ mA Thermal resistance junction to ambient air I = 4 mm, TL = constant RthJA 300 K/W Junction temperature Tj 175 °C Storage temperature range Tstg -65 to +175 °C Forward voltage (max.) IF = 200 mA VF 1.1 V Rev. 2.2, 11-Mar-2019
1
Document Number: 85588 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
