Datasheet DA9130 (Dialog Semiconductor) - 26
ManufacturerDialog Semiconductor
DescriptionHigh-Performance, 10 A, Dual-Phase DC-DC Converter
Pages / Page44 / 26 — DA9130. High-Performance, 10 A, Dual-Phase DC-DC. Converter. Figure 11: …
DA9130. High-Performance, 10 A, Dual-Phase DC-DC. Converter. Figure 11: I2C Byte Read (SDA Line) Examples. Datasheet
DA9130 High-Performance, 10 A, Dual-Phase DC-DC Converter Figure 11: I2C Byte Read (SDA Line) Examples Datasheet
link to page 26
When the host reads data from a register it first has to write to DA9130 with the target register address and then read from DA9130 with a repeated START, or alternatively a second START, condition. After receiving the data, the host sends no acknowledge (A*) and terminates the transmission with a STOP condition, see Figure 11. S SLAVEadr W A REGadr A SLAVEadr A DATA A* Sr R P 7-bits 1-bit 8-bits 7-bits 1-bit 8-bits S SLAVEadr W A REGadr A P S SLAVEadr R A DATA A* P 7-bits 1-bit 8-bits 7-bits 1-bit 8-bits Master to Slave Slave to Master S = START condition A = Acknowledge (low) Sr = Repeated START condition A* = No Acknowledge P = STOP condition W = Write (low) R = Read (high)
Figure 11: I2C Byte Read (SDA Line) Examples Datasheet Revision 1.0 31-Aug-2020
CFR0011-120-00 26 of 44 © 2020 Dialog Semiconductor Document Outline General Description Key Features Benefits Applications System Diagrams Contents Table of Figures Table of Tables 1 Terms and Definitions 2 Pinout 3 Characteristics 3.1 Absolute Maximum Ratings 3.2 Recommended Operating Conditions 3.3 Thermal Characteristics 3.3.1 Thermal Ratings 3.3.2 Power Dissipation 3.4 ESD Characteristics 3.5 Buck Characteristics 3.6 Performance and Supervision Characteristics 3.7 Digital IO Characteristics 3.8 Timing Characteristics 3.9 Typical Performance 4 Functional Description 4.1 DC-DC Buck Converter 4.1.1 Switching Frequency 4.1.2 Operation Modes and Phase Selection 4.1.3 Output Voltage Selection 4.1.4 Soft Start-Up and Shutdown 4.1.5 Current Limit 4.1.6 Resistive Divider 4.1.7 Thermal Protection 4.2 Internal Circuits 4.2.1 IC_EN/Chip Enable/Disable 4.2.2 nIRQ/Interrupt 4.2.3 GPIO 4.2.3.1 GPIO Pin Assignment 4.2.3.2 GPIO Function 4.2.3.3 Chip Configuration Select (CONF) 4.3 Operating Modes 4.3.1 ON 4.3.2 OFF 4.4 I2C Communication 4.4.1 I2C Protocol 5 Register Definitions 5.1 Register Map 5.1.1 System 5.1.2 Buck1 5.1.3 Serialization 6 Package Information 6.1 Package Outlines 6.2 Moisture Sensitivity Level 6.3 Soldering Information 7 Ordering Information 8 Application Information 8.1 Capacitor Selection 8.2 Inductor Selection
