Datasheet LTC6373 (Analog Devices) - 3
Description36V Fully-Differential Programmable-Gain Instrumentation Amplifier with 25pA Input Bias Current
Pages / Page34 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 4.0 Mb
LTC6373
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications and all typical values are at TA = 25°C. V+ = V+OUT = 15V, V– = –15V, VICM = VOCM = DGND = 0V, G = 1 (A2 = 5V, A1 = A0 = 0V). VS is defined as (V+ – V–). VICM is defined as (V+IN + V–IN)/2. VOUTCM is defined as (V+OUT + V–OUT)/2. VOUTDIFF is defined as (V+OUT – V–OUT). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
GDIFF Differential Gain Range G = 16, 8, 4, 2, 1, 0.5, 0.25 0.25 16 V/V ∆GDIFF Differential Gain Error (Note 11) G = 4, 2, 1, 0.5, 0.25 0.002 0.012 % G = 4, 2, 1, 0.5, 0.25 l 0.02 % G = 16, 8 0.003 0.015 % G = 16, 8 l 0.023 % ∆GDIFF/∆T Differential Gain Drift (Note 6) l 0.25 1 ppm/°C GNL Differential Gain Nonlinearity (Note 11) VOUTDIFF = 40VP-P 1 3 ppm l 10 ppm VOSDIFF Differential Offset Voltage (Input Referred) G = 16, 8, 4, 2, 1, 0.5, 0.25 10 + 40/G 80 + 192/G μV (Note 7) TA = –40°C to 85°C l 250 + 400/G μV TA = –40°C to 125°C l 1120 + 1120/G μV ∆VOSDIFF/∆T Differential Offset Voltage Drift G = 16, 8, 4, 2, 1, 0.5, 0.25 (Input Referred) (Note 6) TA = –40°C to 85°C l 0.3 + 0.5/G 1.5 + 2.5/G μV/°C TA = –40°C to 125°C l 2 + 1.5/G 5 + 5.5/G μV/°C Differential Offset Voltage Hysteresis (Input G = 16, 8, 4, 2, 1, 0.5, 0.25 l 10 + 15/G μV Referred) (Note 12) IB Input Bias Current (Notes 7, 8) Active 2 25 pA TA = –40°C to 85°C l 50 pA TA = –40°C to 125°C l 500 pA Shutdown (A2 = A1 = A0 = 5V) 20 pA IOS Input Offset Current (Notes 7, 8) Active 2 25 pA TA = –40°C to 85°C l 40 pA TA = –40°C to 125°C l 100 pA Shutdown (A2 = A1 = A0 = 5V) 5 pA en Differential Input Voltage Noise Density f = 10kHz G = 16 8 nV/√Hz G = 8 8.4 nV/√Hz G = 4 9.5 nV/√Hz G = 2 12.2 nV/√Hz G = 1 18.7 nV/√Hz G = 0.5 26.4 nV/√Hz G = 0.25 41 nV/√Hz Differential Input Voltage Noise 0.1Hz to10Hz G = 16 1.1 μVP-P G = 8 1.2 μVP-P G = 4 1.3 μVP-P G = 2 1.5 μVP-P G = 1 1.8 μVP-P G = 0.5 2.4 μVP-P G = 0.25 4.2 μVP-P in Input Current Noise Density f = 10kHz 1 fA/√Hz Input Current Noise 0.1Hz to 10Hz 100 fAP-P enVOCM Common Mode Voltage Noise Density f = 10kHz 24 nV/√Hz RIN Input Resistance Differential Mode 5×1012 Ω Common Mode 5×1012 Ω CIN Input Capacitance 15 pF VINR Input Voltage Range V– + 3 V+ – 3 V l V– + 3.25 V+ – 3 V Rev. 0 For more information www.analog.com 3 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Block Diagram Applications Information Package Description Typical Application Related Parts
