link to page 9 AD8426ABSOLUTE MAXIMUM RATINGSTHERMAL RESISTANCETable 8. Parameter Rating The θJA value in Table 9 assumes a 4-layer JEDEC standard Supply Voltage ±18 V board with zero airflow. Output Short-Circuit Current Indefinite Table 9. Maximum Voltage at −INx or +INx −VS + 40 V Package θ Minimum Voltage at −INx or +INx +V JA Unit S − 40 V REFx Voltage ±V 16-Lead LFCSP (CP-16-19) 86 °C/W S Storage Temperature Range −65°C to +150°C Specified Temperature Range −40°C to +125°C ESD CAUTION Maximum Junction Temperature 130°C ESD Human Body Model 1.5 kV Charged Device Model 1.5 kV Machine Model 100 V Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. 0 | Page 9 of 28 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL-SUPPLY OPERATION Dynamic Performance Specifications SINGLE-SUPPLY OPERATION Dynamic Performance Specifications ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ARCHITECTURE GAIN SELECTION REFERENCE TERMINAL INPUT VOLTAGE RANGE LAYOUT Package Considerations Hidden Paddle Package Common-Mode Rejection Ratio over Frequency Power Supplies References INPUT BIAS CURRENT RETURN PATH INPUT PROTECTION RADIO FREQUENCY INTERFERENCE (RFI) APPLICATIONS INFORMATION PRECISION STRAIN GAGE DIFFERENTIAL DRIVE Differential Output Using Both AD8426 Amplifiers 2-Channel Differential Output Using a Dual Op Amp Tips for Best Differential Output Performance DRIVING A CABLE DRIVING AN ADC OUTLINE DIMENSIONS ORDERING GUIDE
