24 /10 — AD8229. Data Sheet. GAIN = 1000. VS = ±15V. –10. A) n. GAIN = 100. –15. …
Revision
B
PDF / 941 Kb
AD8229. Data Sheet. GAIN = 1000. VS = ±15V. –10. A) n. GAIN = 100. –15. –12.28V. –20. B) d. GAIN = 10. –25. CURRE. N ( AI. 12.60V. –30. BI UT. GAIN = 1. –35
AD8229Data Sheet070GAIN = 1000VS = ±15V–560–1050A) nGAIN = 100(–1540–12.28VNT–2030B) dGAIN = 10–25CURRE20N ( AIAS12.60V–30G10BI UTGAIN = 1–350INP–40–10–45–20–50–30–14 –12 –10 –8–6–4–202468101214 068 1001k10k100k1M10M100M 017 COMMON-MODE VOLTAGE (V) 09412- FREQUENCY (Hz) 09412- Figure 17. Input Bias Current vs. Common-Mode Voltage Figure 20. Gain vs. Frequency 160160GAIN = 1000GAIN = 1000GAIN = 100GAIN = 100140GAIN = 10140GAIN = 10GAIN = 1GAIN = 1) 120120B (d R 100100BANDWIDTHB) dLIMITED8080IVE PSR TRR (SICM6060PO404020200 9 01101001k10k100k1M -06 1101001k10k100k1M 018 FREQUENCY (Hz) 09412 FREQUENCY (Hz) 09412- Figure 18. Positive PSRR vs. Frequency Figure 21. CMRR vs. Frequency 160160GAIN = 1000 GAIN = 100140GAIN = 10140GAIN = 1120B)120d R ( 100100PSRB) dGAIN = 1000BANDWIDTH80IVE80GAIN = 100LIMITEDTRR (AGAIN = 10CMGAIN = 1EG6060N404020200 0 01101001k10k100k1M -07 1101001k10k100k1M 019 FREQUENCY (Hz) 09412 FREQUENCY (Hz) 09412- Figure 19. Negative PSRR vs. Frequency Figure 22. CMRR vs. Frequency, 1 kΩ Source Imbalance Rev. B | Page 10 of 24 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Predicted Lifetime vs. Operating Temperature Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Architecture Gain Selection RG Power Dissipation Reference Terminal Input Voltage Range Layout Common-Mode Rejection Ratio over Frequency Power Supplies Reference Pin Input Bias Current Return Path Input Protection Input Voltages Beyond the Rails Large Differential Input Voltage at High Gain IMAX Radio Frequency Interference (RFI) Calculating the Noise of the Input Stage Source Resistance Noise Voltage Noise of the Instrumentation Amplifier Current Noise of the Instrumentation Amplifier Total Noise Density Calculation Outline Dimensions Ordering Guide
