Datasheet AD8227 (Analog Devices) - 8
DescriptionWide Supply Range, Rail-to-Rail Output Instrumentation Amplifier
Pages / Page24 / 8 — AD8227. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. –IN. +VS. RG 2. …
File Format / SizePDF / 666 Kb
AD8227. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. –IN. +VS. RG 2. VOUT. RG 3. REF. +IN. –VS. TOP VIEW. (Not to Scale)
AD8227 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS –IN +VS RG 2 VOUT RG 3 REF +IN –VS TOP VIEW (Not to Scale)
AD8227 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS AD8227 –IN 1 8 +VS RG 2 7 VOUT RG 3 6 REF +IN 4 5 –VS
2
TOP VIEW
00 9-
(Not to Scale)
75 07 Figure 2. Pin Configuration
Table 6. Pin Function Descriptions Pin No. Mnemonic Description
1 −IN Negative Input. 2, 3 RG Gain Setting Pins. Place a gain resistor between these two pins. 4 +IN Positive Input. 5 −VS Negative Supply. 6 REF Reference. This pin must be driven by low impedance. 7 VOUT Output. 8 +VS Positive Supply. Rev. 0 | Page 8 of 24 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ARCHITECTURE GAIN SELECTION REFERENCE TERMINAL INPUT VOLTAGE RANGE LAYOUT Common-Mode Rejection Ratio over Frequency Power Supplies References INPUT BIAS CURRENT RETURN PATH INPUT PROTECTION RADIO FREQUENCY INTERFERENCE (RFI) APPLICATIONS INFORMATION DIFFERENTIAL DRIVE Tips for Best Differential Output Performance PRECISION STRAIN GAGE DRIVING AN ADC OUTLINE DIMENSIONS ORDERING GUIDE
