10 MHz G = 1, 2, 5, 10 iCMOS Programmable Gain Instrumentation Amplifier
Pages / Page
24 /10 — AD8250. Data Sheet. n ( T. URRE C T. V µ. D O. RR (. IB+. IOS. CURRE S. A …
Revision
C
PDF / 848 Kb
AD8250. Data Sheet. n ( T. URRE C T. V µ. D O. RR (. IB+. IOS. CURRE S. A –10 BI. –15. INP. –10. –40 –25 –10. 110 125. –50. –30. 110. 130. TEMPERATURE (°C). 140
AD8250Data Sheet15A)10n ( T8N106URRE C TI4E5B–S)F/VF2V µD O00RR (ANIB+CMNT–2∆–5–4IOSCURRE S–6A –10 BI 9 –8 04 UT 8- 28 –15 06 INP–10–40 –25 –105203550658095110 125 19 –50–30–101030507090110130 0 8- TEMPERATURE (°C) 28 TEMPERATURE (°C) 06 Figure 18. Input Bias Current and Offset Current vs. Temperature Figure 21. CMRR vs. Temperature, G = 1 14025G = 10G = 5G = 102012015G = 5100)B)G = 2G = 1dB10d80(G = 2RR (IN5CMGA60G = 1040–520–101101001k10k100k1M 20 23 0 1k10k100k1M10M100M 0 8- 8- FREQUENCY (Hz) 28 FREQUENCY (Hz) 28 06 06 Figure 19. CMRR vs. Frequency Figure 22. Gain vs. Frequency 14040 f = 1kHzG = 10G = 530120) IV /D20pm10010p (10B)G = 2YdG = 1IT80R0RR (A ECMIN L –1060ON N IN –2040GA –30 24 0 8- 28 20–40 06 1101001k10k100k1M 21 0 –10–8–6–4–20246810 8- FREQUENCY (Hz) 28 OUTPUT VOLTAGE (V) 06 Figure 20. CMRR vs. Frequency, 1 kΩ Source Imbalance Figure 23. Gain Nonlinearity vs. Output Voltage, G = 1, RL = 10 kΩ, 2 kΩ, 600 Ω Rev. C | Page 10 of 24 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Diagram Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Gain Selection Transparent Gain Mode Latched Gain Mode Timing for Latched Gain Mode Power Supply Regulation and Bypassing Input Bias Current Return Path Input Protection Reference Terminal Common-Mode Input Voltage Range Layout Grounding Coupling Noise Common-Mode Rejection RF Interference Driving an ADC Applications Differential Output Setting Gains with a Microcontroller Data Acquisition Outline Dimensions Ordering Guide
