24 /10 — AD8222. Data Sheet. GAIN = 1000. GAIN = 100. ) B. GAIN = 10. EXAMPLE PART …
Revision
B
PDF / 530 Kb
AD8222. Data Sheet. GAIN = 1000. GAIN = 100. ) B. GAIN = 10. EXAMPLE PART 1. R (. GAIN = 1. EXAMPLE PART 2. –10. –20. –15. –30. –40. 100. 10k. 100k. 10M. 120
AD8222Data Sheet7020GAIN = 1000601550GAIN = 100401030)5) BGAIN = 10/VEXAMPLE PART 1d20V(µ0IN10R (GAGAIN = 1CM0∆–5EXAMPLE PART 2–10–10–20–15–30–40–20 5 8 1001k10k100k1M10M 01 –40–20020406080100120 01 7- 7- FREQUENCY (Hz) 94 TEMPERATURE (°C) 94 05 05 Figure 16. Gain vs. Frequency Figure 19. ΔCMR vs. Temperature, G = 1 160+VGAIN = 1000S–0150–0.4GAIN = 100FROM +V140SS E –0.8G130) AT –1.2GAIN = 10(V L120T–1.6BANDWIDTHIMILIMITEDY VOB)110L–2.0dE(GAIN = 1G100A PPLRRT L SU90CMO +2.0FROM –VSVO T80T D +1.6EPU R70IN+1.2ER60EF +0.8R50+0.440–V 6 S+0 9 0.11101001k10k100k1M 01 26101418 01 7- 7- FREQUENCY (Hz) 94 SUPPLY VOLTAGE (V) 94 05 05 Figure 17. CMRR vs. Frequency, RTI Figure 20. Input Voltage Limit vs. Supply Voltage, G = 1 160+VS–0GAIN = 1000150–0.4140SR) EL = 10kΩG –0.8130AGAIN = 100G (V TL –1.2120IN WRL = 2kΩS Y VO –1.6B)110dGAIN = 10E(G PPL100ARRLT SU90BANDWIDTHOCMOLIMITEDV+1.6TTR80DUL = 2kΩE +1.2TP R70ERGAIN = 1OU+0.860EF RRL = 10kΩ+0.45040–V 7 S+0 0 0.11101001k10k100k1M 01 26101418 02 7- 7- FREQUENCY (Hz) 94 SUPPLY VOLTAGE (V) 94 05 05 Figure 18. CMRR vs. Frequency, RTI, 1 kΩ Source Imbalance Figure 21. Output Voltage Swing vs. Supply Voltage, G = 1 Rev. B | Page 10 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION AMPLIFIER ARCHITECTURE GAIN SELECTION REFERENCE TERMINAL PACKAGE CONSIDERATIONS Package Without Thermal Pad Package with Thermal Pad LAYOUT Common-Mode Rejection Over Frequency Reference Power Supplies INPUT BIAS CURRENT RETURN PATH INPUT PROTECTION Input Voltages Beyond the Rails Differential Input Voltages at High Gains RF INTERFERENCE COMMON-MODE INPUT VOLTAGE RANGE APPLICATIONS INFORMATION DIFFERENTIAL OUTPUT Setting the Common-Mode Voltage 2-Channel Differential Output Using a Dual Op Amp DRIVING A DIFFERENTIAL INPUT ADC RFI and Antialiasing Filter Second Antialiasing Filter Reference PRECISION STRAIN GAGE DRIVING CABLING OUTLINE DIMENSIONS ORDERING GUIDE
