AD822554030420– VVS = 5VGE10A T L O30–102GAIN – dB –20–30COMMON-MODE V1–40–500–600123451001k10k100k1M10MOUTPUT VOLTAGE – VFREQUENCY – Hz TPC 13. CMV vs. VOUT, Single Supply TPC 16. Large Signal Frequency Response, VOUT = 4 V p-p 140+VS –0.0120–0.5GES) A –1.0100VT L O5 –V –1.5Y80+VSGE–2.0A05101520T LSUPPLO2.0PSRR – dB 60–VOS1.540INPUT V1.020(REFERRED T0.5–V0S +0.00.11101001k10k100k1M05101520FREQUENCY – HzSUPPLY VOLTAGE –V TPC 14. PSRR vs. Frequency, RTI TPC 17. Input Common Mode Voltage Range vs. Supply Voltage 40+VS 030–0.520RL = 10kVGES) A T –1.010L ORVL = 2kY –1.50–2.0–10GE SWING –02468101214161820A TSUPPLLOGAIN – dB2.0–20O V1.5–30RL = 2k–40OUTPUT1.0–50(REFERENCED T0.5RL = 10k–60–VS 01001k10k100k1M10M02468101214161820FREQUENCY – HzSUPPLY VOLTAGE –V TPC 15. Small Signal Frequency Response, TPC 18. Output Voltage Swing vs. Supply Voltage V and Load Resistance OUT = 200 mV p-p –8– REV. A Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS PIN FUNCTION DESCRIPTIONS ORDERING GUIDE Typical Performance Characteristics Test Circuits THEORY OF OPERATION 47pF 2 5 200mV APPLICATIONS Precision V-to-I Converter Driving a High Resolution ADC Using the Reference Input AD8225 Used as an EKG Front End Benefits of Fast Slew Rates Evaluation Board OUTLINE DIMENSIONS Revision History
