Datasheet AD621 (Analog Devices) - 4
DescriptionLow Drift, Low Power Instrumentation Amplifier
Pages / Page16 / 4 — AD621. ABSOLUTE MAXIMUM RATINGS1. ESD SUSCEPTIBILITY. ORDERING GUIDE. …
File Format / SizePDF / 535 Kb
AD621. ABSOLUTE MAXIMUM RATINGS1. ESD SUSCEPTIBILITY. ORDERING GUIDE. Temperature. Package. Model. Range. Description. Option1
AD621 ABSOLUTE MAXIMUM RATINGS1 ESD SUSCEPTIBILITY ORDERING GUIDE Temperature Package Model Range Description Option1
Supply Voltage . ± 18 V ESD (electrostatic discharge) sensitive device. Electrostatic Internal Power Dissipation2 . 650 mW charges as high as 4000 volts, which readily accumulate on the Input Voltage (Common Mode) . ± V human body and on test equipment, can discharge without S Differential Input Voltage . ± 25 V detection. Although the AD621 features proprietary ESD pro- Output Short Circuit Duration . Indefinite tection circuitry, permanent damage may still occur on these Storage Temperature Range (Q) . –65°C to +150°C devices if they are subjected to high energy electrostatic dis- Storage Temperature Range (N, R) . –65°C to +125°C charges. Therefore, proper ESD precautions are recommended Operating Temperature Range to avoid any performance degradation or loss of functionality. AD621 (A, B) . – 40°C to +85°C AD621 (S) . – 55°C to +125°C
ORDERING GUIDE
Lead Temperature Range
Temperature Package Package
(Soldering 10 seconds) . 300°C
NOTES 1Stresses above those listed under Absolute Maximum Ratings may cause perma- AD621AN – 40°C to +85°C 8-Lead Plastic DIP N-8 nent damage to the device. This is a stress rating only; functional operation of the AD621BN – 40°C to +85°C 8-Lead Plastic DIP N-8 device at these or any other conditions above those indicated in the operational AD621AR – 40°C to +85°C 8-Lead Plastic SOIC R-8 section of this specification is not implied. Exposure to absolute maximum rating AD621BR – 40°C to +85°C 8-Lead Plastic SOIC R-8 conditions for extended periods may affect device reliability. 2 AD621SQ/883B2 –55°C to +125°C 8-Lead Cerdip Q-8 Specification is for device in free air: 8-Lead Plastic Package: θ AD621ACHIPS –40°C to +85°C Die JA = 95°C/W 8-Lead Cerdip Package: θJA = 110°C/W NOTES 8-Lead SOIC Package: θJA = 155°C/W 1N = Plastic DIP; Q = Cerdip; R = SOIC. 2See Analog Devices’ military data sheet for 883B specifications.
METALIZATION PHOTOGRAPH
Dimensions shown in inches and (mm). Contact factory for latest dimensions.
1.125 (3.57) +VS OUTPUT 7 6 RG 8 5 REFERENCE 0.0708 (2.545) RG 1 4 –VS 2 3 –IN +IN
–4– REV. B
