Datasheet AMP01 (Analog Devices) - 5
DescriptionLow Noise, Precision Instrumentation Amplifier
Pages / Page29 / 5 — Data Sheet. AMP01. Table 2. AMP01E. AMP01F/AMP01G. Parameter Sy. Test …
RevisionF
File Format / SizePDF / 439 Kb
Data Sheet. AMP01. Table 2. AMP01E. AMP01F/AMP01G. Parameter Sy. Test Conditions/Commen. mbol ts. Min. Typ. Max. Unit
Data Sheet AMP01 Table 2 AMP01E AMP01F/AMP01G Parameter Sy Test Conditions/Commen mbol ts Min Typ Max Unit
link to page 6 link to page 6 link to page 6 link to page 6
Data Sheet AMP01
VS = ±15 V, RS = 10 kΩ, RL = 2 kΩ, TA = 25°C, −25°C ≤ TA ≤ +85°C for E and F grades, 0°C ≤ TA ≤ 70°C for G grade, unless otherwise noted.
Table 2. AMP01E AMP01F/AMP01G Parameter Sy Test Conditions/Commen mbol ts Min Typ Max Min Typ Max Unit
OFFSET VOLTAGE Input Offset Voltage VIOS TA = 25°C 20 50 40 100 μV TMIN ≤ TA ≤ TMAX 40 80 60 150 μV Input Offset Voltage Drift TCV 1 IOS TMIN ≤ TA ≤ TMAX 0.15 0.3 0.3 1.0 μV°C Output Offset Voltage VOOS TA = 25°C 1 3 2 6 mV TMIN ≤ TA ≤ TMAX 3 6 6 10 mV Output Offset Voltage Drift TCVOOS RG = ∞1 −55°C ≤ TA ≤ +125°C 20 100 50 120 μV/°C Offset Referred to Input vs. PSR V+ = +5 V to +15 V Positive Supply G = 1000 120 130 110 120 dB G = 100 110 130 100 120 dB G = 10 95 110 90 100 dB G = 1 75 90 70 80 dB TMIN ≤ TA ≤ TMAX G = 1000 120 130 110 120 dB G = 100 110 130 100 120 dB G = 10 95 110 90 100 dB G = 1 75 90 70 80 dB Offset Referred to Input vs. PSR V− = −5 V to −15 V Negative Supply G = 1000 110 125 105 115 dB G = 100 95 105 90 95 dB G = 10 75 85 70 75 dB G = 1 55 65 50 60 dB TMIN ≤ TA ≤ TMAX G = 1000 110 125 105 115 dB G = 100 95 105 90 95 dB G = 10 75 85 70 75 dB G = 1 55 85 50 60 dB Input Offset Voltage Trim Range VS = ±4.5 V to ±18 V2 ±6 ±6 mV Output Offset Voltage Trim Range VS = ±4.5 V to ±18 V2 ±100 ±100 mV INPUT CURRENT Input Bias Current IB TA = 25°C 1 4 2 6 nA TMIN ≤ TA ≤ TMAX 4 10 6 15 nA Input Bias Current Drift TCIB TMIN ≤ TA ≤ TMAX 40 50 pA/°C Input Offset Current IOS TA = 25°C 0.2 1.0 0.5 2.0 nA TMIN ≤ TA ≤ TMAX 0.5 3.0 1.0 6.0 nA Input Offset Current Drift TCIOS TMIN ≤ TA ≤ TMAX 3 5 pA/°C Rev. F | Page 5 of 29 Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS DICE CHARACTERISTICS WAFER TEST LIMITS (AMP01NBC) ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT AND OUTPUT OFFSET VOLTAGES INPUT BIAS AND OFFSET CURRENTS GAIN COMMON-MODE REJECTION ACTIVE GUARD DRIVE GROUNDING SENSE AND REFERENCE TERMINALS DRIVING 50 Ω LOADS HEATSINKING OVERVOLTAGE PROTECTION POWER SUPPLY CONSIDERATIONS APPLICATIONS CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
