AD624ModelAD624AAD624BAD624CAD624SMinTypMaxMinTypMaxMinTypMaxMinTypMaxUnits REFERENCE INPUT RIN 16 20 24 16 20 24 16 20 24 16 20 24 kΩ IIN 30 30 30 30 µA Voltage Range ±10 ±10 ±10 ±10 V Gain to Output 1 1 1 1 % TEMPERATURE RANGE Specified Performance –25 +85 –25 +85 –25 +85 –55 +125 °C Storage –65 +150 –65 +150 –65 +150 –65 +150 °C POWER SUPPLY Power Supply Range ⴞ 6 ⴞ 15 ⴞ 18 ⴞ 6 ⴞ 15 ⴞ 18 ⴞ 6 ⴞ 15 ⴞ 18 ⴞ 6 ⴞ 15 ⴞ 18 V Quiescent Current 3.5 5 3.5 5 3.5 5 3.5 5 mA NOTES 1VDL is the maximum differential input voltage at G = 1 for specified nonlinearity, VDL at other gains = 10 V/G. VD = actual differential input voltage. 1Example: G = 10, VD = 0.50. VCM = 12 V – (10/2 × 0.50 V) = 9.5 V. Specifications subject to change without notice. Specifications shown in boldface are tested on all production unit at final electrical test. Results from those tests are used to calculate outgoing quality levels. All min and max specifications are guaranteed, although only those shown in boldface are tested on all production units. ABSOLUTE MAXIMUM RATINGS*CONNECTION DIAGRAM Supply Voltage . ± 18 V Internal Power Dissipation . 420 mW Input Voltage . ± V –INPUT116 RG1 S Differential Input Voltage . ± V +INPUT215 OUTPUT NULL S Output Short Circuit Duration . Indefinite RG2 314 OUTPUT NULL Storage Temperature Range . –65°C to +150°C INPUT NULLAD624413 G = 100SHORT TO Operating Temperature Range TOP VIEWRGINPUT NULL512 G = 2002 FOR(Not to Scale)DESIRED AD624A/B/C . –25°C to +85°C REF611 G = 500GAIN AD624S . –55°C to +125°C –VS 710 SENSE Lead Temperature (Soldering, 60 secs) . +300°C +VS 89OUTPUT *Stresses above those listed under Absolute Maximum Ratings may cause perma- nent damage to the device. This is a stress rating only; functional operation of the FOR GAINS OF 1000 SHORT RG1 TO PIN 12 device at these or any other conditions above those indicated in the operational AND PINS 11 AND 13 TO RG2 sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. METALIZATION PHOTOGRAPH Contact factory for latest dimensions ORDERING GUIDE Dimensions shown in inches and (mm). TemperaturePackagePackageModelRangeDescriptionOption AD624AD –25°C to +85°C 16-Lead Ceramic DIP D-16 AD624BD –25°C to +85°C 16-Lead Ceramic DIP D-16 AD624CD –25°C to +85°C 16-Lead Ceramic DIP D-16 AD624SD –55°C to +125°C 16-Lead Ceramic DIP D-16 AD624SD/883B* –55°C to +125°C 16-Lead Ceramic DIP D-16 AD624AChips –25°C to +85°C Die AD624SChips –25°C to +85°C Die *See Analog Devices’ military data sheet for 883B specifications. REV. C –3–
