Datasheet TLP3475SRHA (Toshiba)
Manufacturer | Toshiba |
Description | Photocouplers Photorelay |
Pages / Page | 11 / 1 — TLP3475SRHA. Photocouplers. Photorelay. TLP3475SRHA. 1. Applications. … |
File Format / Size | PDF / 326 Kb |
TLP3475SRHA. Photocouplers. Photorelay. TLP3475SRHA. 1. Applications. (Note). •. ATE. (Automatic. Test. Equipment). •. Probe. Cards. •. Measuring
TLP3475SRHA Photocouplers Photorelay TLP3475SRHA 1. Applications (Note) • ATE (Automatic Test Equipment) • Probe Cards • Measuring Instruments • High-Speed Logic IC Testers • High-Speed Memory Testers 2. General The TOSHIBA TLP3475SRHA is a very small outline non-leaded photorelay suitable for surface-mount assembly. It is housed in a S-VSON4T package. TLP3475SRHA has a Built-in input resistor, which eliminates an external input resistor for space saving. Its features include low off-state current and low output pin capacitance. 3. Features (1) S-VSON4T: 2.0 (L) mm × 1.45 (W) mm × 1.3 (H) mm (2) Operating temperature: -40 to 125 (3) Normally opened (1-Form-A) (4) OFF-state output terminal voltage: 60 V (min) (5) Operating voltage: 3 V (max) (6) ON-state current: 400 mA (max) (7) Output capacitance: 12 pF (typ.) ,20 pF (max) (8) ON-state resistance: 1 Ω (typ.), 1.5 Ω (max) (9) Isolation voltage: 500 Vrms (min) (10) Halogen-free For details, see "Devices in Halogen-Free Resin Packages" at the end of this datasheet. 4. Packaging and Pin Assignment 1: Anode 2: Cathode 3: Drain 4: Drain 11-2E2 Start of commercial production 2020-06 ©2020 1 2020-07-06 Toshiba Electronic Devices & Storage Corporation Rev.1.0
