Datasheet SRF4530A (Bourns)
ManufacturerBourns
Description Common Mode Chip Inductors, CANbus
Pages / Page5 / 1 — *RoHS COMPLIANT. VERSIONS. AVAILABLE. LEAD FREE. ARE. RoHS COMPLIANT*. …
File Format / SizePDF / 713 Kb
*RoHS COMPLIANT. VERSIONS. AVAILABLE. LEAD FREE. ARE. RoHS COMPLIANT*. APPROVED. & AEC. Features. AUTOMOTIVE. , **HALOGEN FREE 110. 2024
Datasheet SRF4530A Bourns
*RoHS COMPLIANT VERSIONS AVAILABLE *RoHS COMPLIANT LEAD FREE ARE LEAD FREE VERSIONS RoHS COMPLIANT* APPROVED *RoHS COMPLIANT & AEC Features AUTOMOTIVE
GRADE n Shielded construction – low radiation n Bifilar wound
, **HALOGEN FREE 110 2024
n High temperature
& AEC COMPLIANT T
n AEC-Q200 compliant
*RoHS COMPLIANT
n RoHS compliant* and halogen 4.5 ± 0.2 free**
*RoHS and
(.177 ± .008)
AEC-Q200 COMPLIANT *RoHS COMPLIANT and **HALOGEN FREE SRF4530A Series - Common Mode Chip Inductors,
3.2 ± 0.2 (.126 ± .008) 110 T
CANbus
YYWW
Electrical Specifications @ 25 °C General Specifications
Rated Voltage .. 50 VDC
Leakage L (µH) Common Mode Inductance @ 100 kHz Impedance
Insulation Resistance
@ 100 kHz / 0.1 V / 0.1 V
3.00 0.2
@ 10 MHz
...10 megohms min. @ 50 VDC
DCR
(.118)
Bourns L
(.008) 4.5 ± 0.2
Tolerance Typ. Min. Typ. Max. Irms
Operating Temperature MAX.
Part Number (µH)
MIN. (.177 ± .008)
(%) (µH) (k
W
) (k
W
W
) (A)
..-55 °C to +150 °C SRF4530A-110Y 11.0 +50 / -30 0.10 0.30 0.60 0.50 0.36 (Temperature rise included) 3.80 REF. Storage Temperature SRF4530A-220Y 22.0 +50 / -30 0.15 0.60 1.20 COPLANARITY WITHIN 80 µm (.150) 0.60 0.31 ..-55 °C to +150 °C 2 3 3.2 ± 0.2 (.126 ± .008) 110 SRF4530A-510Y 51.0 T +50 / -30 0.25 1.50 3.50 1.00 0.23 Temperature Rise ...40 °C at rated Irms SRF4530A-101Y 100.0 YYWW +50 / -30 0.30 3.00 7.50 1.50 0.20
Materials
0.65
Product Dimensions
(.026) Core ..Ferrite REF. Wire ..Enameled copper 4.5 ± 0.2 (.177 ± .008) Terminal Finish ...Au 3.00 Packaging ... 500 pcs. per 7-inch reel 0.2 1 (.118) 0.70 4 (.008) MAX. MIN. (.028) 3.2 ± 0.2
How to Order
(.126 ± .008) 110 T 3.80 YYWW REF. COPLANARITY WITHIN 80 µm
SRF4530A - 220 Y
(.150) 2 3 Model Value Code (see table) Tolerance Code 0.65 (.026) 3.00 REF. 0.2 (.118) (.008) MAX.
Typical Part Marking
MIN. MODEL CODE 1 0.70 3.80 4 REF. COPLANARITY WITHIN 80 µm MANUFACTURING (.028) (.150) 2 3 LOCATION • M = MALAYSIA 110 T • T = TAIWAN 3.40 1.60 0.65 (.139) (.063) YYWW (.026) REF. DIMENSIONS: MM (INCHES) MANUFACTURING DATE CODE: 3.00 • 1ST & 2ND DIGITS INDICATE THE YEAR 1 (.118) • 3RD & 4TH DIGITS INDICATE THE WEEK NUMBER 0.70 4 5.90 (.028) (.232)
Recommended Layout Schematic WARNING Cancer and Reproductive Harm
1 N1 4 www.P65Warnings.ca.gov * RoHS Directive 2015/863, Mar 31, 2015 and Annex. 3.40 1.60 (.139) (.063) ** Bourns considers a product to be “halogen free” if (a) the Bromine (Br) content is 900 ppm or less; (b) the Chlorine (Cl) content is 900 ppm or less; and (c) 2 3 N2 the total Bromine (Br) and Chlorine (Cl) content is 1500 ppm or less. 3.00 Specifications are subject to change without notice. (.118) Users should verify actual device performance in their 5.90 specific applications. (.232) The products described herein and this document are subject to specific legal disclaimers as set forth on the DIMENSIONS: MM last page of this document, and at www.bourns.com/ 3.40 1.60 (INCHES) (.139) (.063) docs/legal/disclaimer.pdf. 1 N1 4 3.00 (.118) 2 3 N2 5.90 (.232) 1 N1 4 2 3 N2
