Datasheet BA45F5420 (Holtek) - 5
ManufacturerHoltek
Description9V High Voltage Smoke Detector Flash MCU
Pages / Page112 / 5 — BA45F5420. 9V High Voltage Smoke Detector Flash MCU. Instruction Set …
BA45F5420. 9V High Voltage Smoke Detector Flash MCU. Instruction Set Summary ...98. Instruction Definition ..100
BA45F5420 9V High Voltage Smoke Detector Flash MCU Instruction Set Summary ...98 Instruction Definition ..100
link to page 96 link to page 96 link to page 97 link to page 97 link to page 97 link to page 97 link to page 97 link to page 98 link to page 98 link to page 100 link to page 109 link to page 110 link to page 111
BA45F5420 BA45F5420 9V High Voltage Smoke Detector Flash MCU 9V High Voltage Smoke Detector Flash MCU
Moving and Transferring Data ...96 Arithmetic Operations ..96 Logical and Rotate Operation ...97 Branches and Control Transfer ...97 Bit Operations ...97 Table Read Operations ...97 Other Operations ...97
Table Conventions ...98
Instruction Definition ..100 Package Information ..109
16-pin NSOP (150mil) Outline Dimensions ... 110 20-pin SOP (300mil) Outline Dimensions ... 111 Rev. 1.00 4 June 15, 2020 Rev. 1.00 5 June 15, 2020 Document Outline Features CPU Features Peripheral Features General Description Block Diagram Pin Assignment Pin Description Absolute Maximum Ratings D.C. Electrical Characteristics Operating Voltage Characteristics Standby Current Characteristics Operating Current Characteristics A.C. Electrical Characteristics High Speed Internal Oscillator – HIRC – Frequency Accuracy Low Speed Internal Oscillator Characteristics – LIRC System Start Up Time Characteristics Input/Output Characteristics Memory Characteristics Internal Reference Voltage Electrical Characteristics LVR Electrical Characteristics Sink Current Generator Electrical Characteristics Operational Amplifier Electrical Characteristics A/D Converter Electrical Characteristics LDO Electrical Characteristics Piezoelectric Horn Driver Characteristics Power-on Reset Characteristics System Architecture Clocking and Pipelining Program Counter Stack Arithmetic and Logic Unit – ALU Flash Program Memory Structure Special Vectors Look-up Table Table Program Example In Circuit Programming – ICP On-Chip Debug Support – OCDS RAM Data Memory Structure General Purpose Data Memory Special Purpose Data Memory Special Function Register Description Indirect Addressing Register – IAR0, IAR1 Memory Pointers – MP0, MP1 Accumulator – ACC Program Counter Low Register – PCL Look-up Table Registers – TBLP, TBLH Status Register – STATUS Emulated EEPROM Data Memory Emulated EEPROM Data Memory Structure Emulated EEPROM Registers Erasing the Emulated EEPROM Writing Data to the Emulated EEPROM Reading Data from the Emulated EEPROM Programming Considerations Oscillators Oscillator Overview System Clock Configurations Internal RC Oscillator – HIRC Internal 32kHz Oscillator – LIRC Operating Modes and System Clocks System Clocks System Operation Modes Control Registers Operating Mode Switching Standby Current Considerations Wake-up Watchdog Timer Watchdog Timer Clock Source Watchdog Timer Control Register Watchdog Timer Operation Reset and Initialisation Reset Functions Reset Initial Conditions Input/Output Ports Pull-high Resistors Port A Wake-up I/O Port Control Registers Sink Current Generator Pin-shared Functions I/O Pin Structures Programming Considerations Timer Modules – TM Introduction TM Operation TM Clock Source TM Interrupts TM External Pins Programming Considerations Periodic Type TM – PTM Periodic Type TM Operation Periodic Type TM Register Description Periodic Type TM Operating Modes Smoke Detector AFE Smoke Detector AFE Registers Operational Amplifier Operation Piezoel Horn Driver Analog to Digital Converter A/D Overview Registers Descriptions A/D Converter Reference Voltage A/D Converter Input Signals A/D Converter Operation Conversion Rate and Timing Diagram Summary of A/D Conversion Steps Programming Considerations A/D Transfer Function A/D Programming Examples Interrupts Interrupt Registers Interrupt Operation External Interrupt Timer Module Interrupts A/D Converter Interrupt Time Base Interrupts Interrupt Wake-up Function Programming Considerations Application Circuits External-driving Buzzer Application Circuit Self-driving Buzzer Application Circuit Instruction Set Introduction Instruction Timing Moving and Transferring Data Arithmetic Operations Logical and Rotate Operation Branches and Control Transfer Bit Operations Table Read Operations Other Operations Instruction Set Summary Table Conventions Instruction Definition Package Information 16-pin NSOP (150mil) Outline Dimensions 20-pin SOP (300mil) Outline Dimensions
